• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Active Contributor
    leech10
    Spline
    208 Views, 4 Replies
    11-11-2012 10:50 AM
    Hello
    I made clutch disc. I drawn it in and at the beginning I had a problem with revolve function. Finally I used sketch doctor and I did my part. I wanted to add spline and now problem occured. I cannot select one of the surfaces The end one in screenshot highlighted by red arrow.( I attached second screenshot when face for creation of spline can be selected, but why this end one cannot be?).
    How can I amend my project to be able to add the spline. I think problem is with sketch creation and sketch doctor. I drawn this part by drawning one line, clicking Ok then second, then third etc. then I connected evberything with the sketch docotr( closing loops and doing constraints)
    I made this element before but I drawn it at once( then spline could be made), not by drawing separate lines, however I would like to be able to draw it with separate lines which I need to connect as it is good for me to add curves or circular shaper. please help me with solving this issue
    Regards
    Peter
    Please use plain text.
    Re: Spline
    11-11-2012 11:04 AM in reply to: leech10
    Can you attach the ipt file here?
    Active Contributor
    leech10
    Re: Spline
    11-11-2012 02:43 PM in reply to: leech10
    Hi
    Please see attached
    Regards
    Piotr
    Re: Spline
    11-11-2012 02:56 PM in reply to: leech10
    Your sketch  is not constrained.
    The centerline is not horzontal.
    The small line at right end in image is not vertical - resulting in a face that is not planar when you Revolve.
    I recommend you start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    A proper sketch (and designed for manufacture part) should look something like this.
    Active Contributor
    leech10
    Re: Spline
    11-12-2012 02:18 AM in reply to: leech10
    <p>Hi<p><br><p><br><p><br><p>Thank you I finished my project
