• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Spiral metal plate?
    286 Views, 3 Replies
    10-22-2012 06:26 PM
    Anyone know how I would make the attached image?
    The plate should be .25" thick.
    I've messed around with the helix - spiral function but it always makes a spiral that is already extruded as opposed to just giving me a spiral (like in a sketch) that I can then use another way..  <-- See image.
    Thanks in adavece.
    Please use plain text.
    Active Contributor
    Re: Spiral metal plate?
    10-22-2012 10:21 PM in reply to: ewolfy
    extrude a circle, extrude cut the slice (pie shape) sketch on slice face, spiral cut using the coil command.
    M6400, FX3700M, 16GB, SSD
    Win 7 64
    Inventor 2014
    New Member
    10-22-2012 10:43 PM in reply to: hosford
    I don't get the "spiral cut using the coil command" part..
    10-23-2012 04:42 AM in reply to: ewolfy
    See attached image.
    Attach your file here if you can't figure it out.
    Inventor Professional 2014 Edu 64-bit
