• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Stemdriller
    Someone please help me!!!!
    181 Views, 5 Replies
    02-19-2013 08:36 AM
    All i am trying to do is when an iProperty exceeds a certain length it drops to a second line and not continues in one straight line, thus infringing on other items. This is within a title block.
    I have gone through the whole 'Text Box' area, and for life of me cannot do it.
    Why do AutoDesk make it so complicated?
    Please anyone, I have wasted a whole afternoon on this and destroyed two mice with frustration!
    GW
    Please use plain text.
    cbenner
    Re: Someone please help me!!!!
    02-19-2013 08:44 AM in reply to: Stemdriller
    First thing is... breeeaaathe.
    I placed my text box within the field area and stretched it to fill, then made the text center justified.  See pic:
    Then when I entered the description on iproperties, it will continually wrap until it runs out of text box space... so far never had one that long.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Valued Mentor
    mpatchus
    02-19-2013 08:47 AM in reply to: Stemdriller
    If the text is set to a "TEXT BOX", the data in the iProperty should break into multiple lines as shown.. This one is pulling the model's COMMENTS iProperty.
    Result....
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Valued Mentor
    CelticDesignServices
    02-19-2013 08:49 AM in reply to: cbenner
    I ran into the same issues a while back but then realized if I simply stretched the text box as shown in the above post, the text wrapped downward and all was fine.
    Granted, I always found it works best if you stretch the text box to just inside the text area of the title block. In other words, don't stretch the text box to be right on top of the title block box.
    Unless there's some odd setting you have set, this process has worked flawlessly for years now and I've had some very long titles, 3-4 lines within a 6" wide box with .26" high letters.
    Jim
    Celtic Design Services, LLC
    Inventor/AutoCAD/Vault WorkGroups
    Always for hire - celticdesign01ATyahooDOTcom
    http://www.linkedin.com/pub/celticdesignservices-llc/51/610/398/
    Please use the Accept as Solution and Give Kudos functions as appropriate to further enhance the value of these forums.
    Go raibh maith agat (in other words...Thank you!)
    Valued Mentor
    mpatchus
    02-19-2013 08:55 AM in reply to: CelticDesignServices
    We dimension the text box to .06" from the area to be filled with text.
    One thing to keep in mind, if the iProperty data does not include any "spaces", the text may not break into multiple line properly.
    We ran into this issue when our folks were entering text without spaces (i.e.  ELBOW,90DEG,2"IPS....  etc.).
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    Valued Contributor
    Stemdriller
    02-19-2013 11:32 PM in reply to: mpatchus
    It looks like I need to eat some humble pie!
    The data i was using as a test was '1111111111111111111111111111111111111111'
    Of course there is no spaces! DOH! and Double DOH!
    It is now working perfectly.
    Thanks for everyones response though
    GW
