You may be right. Its hard to say whether its the shell or the fillet. I
was able to redefine the fillet and it worked*.
*Note that I needed to use fillet twice. If I do it in one command, it
doesn't let me - blows up.
I remember someone had a sheetmetal problem where one side worked but the
other side couldn't execute the same command even though it was a mirrored
part.
VR
"darvinv" <darvinvREM@avicomREM.net> wrote in message
news:4005b13e_1@statler...
> jd,
> I think it's the 50 mm fillet. I've recreated everything after
> extrusion2, three different ways, and I cannot get that fillet to blend
> properly at the top. Something goofy in THIS ipt, that does not occur in
> the other.
> darvin
> "JDMATHER" <nospam@address.withheld> wrote in message
> news:27440154.1074114231288.JavaMail.jive@jiveforum2.autodesk.com...
> > Larry
> > If I take the EOP on you part just above shell and then back down
> everything is OK, but if I take it all the way to the top and then back
> down step-by-step it fails.
> > Unless I do a rebuild all.
> > Message was edited by: JDMATHER
Attachment not added (too large): "Front Bracket bad - made good.zip"
