• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Small diameter square tube?
    642 Views, 8 Replies
    02-26-2011 01:14 PM
    how can I get square tube as small as 1 inch in frame generator. The smallest I have is 1 1/4. Is there a content library that I can download that has smaller square tubing.
    Please use plain text.
    Re: Small diameter square tube?
    02-26-2011 01:39 PM in reply to: kdlklm
    You can publish your own profiles to the Content Center for use in the Frame Generator.
    Inventor Professional 2014 Edu 64-bit
    Active Contributor
    02-26-2011 02:04 PM in reply to: JDMather
    is there some kind of tutorial on how to do that in Inventor 2011.
    *Pro
    02-26-2011 06:32 PM in reply to: kdlklm
    Here's a start.
    http://teknigroup.com/AU2008
    ____________________________________________________________
    Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
    Autodesk Manufacturing Implementation Certified Expert
    Autodesk Silver Manufacturing Partner
    Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
    XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
    Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
    Active Member
    01-14-2013 10:15 AM in reply to: Dennis_Jeffrey
    I totally understand and appreciate the ability to create custom shaped extrusions. However, I count no less than 27 sizes of square steel tubing smaller than 1 1/4"  available right now from my steel supplier. Why does Inventor's library arbitrarily start at 1 1/4"? Expecting every user to custom make every COMMON size of extrusion is unfortunate on a CAD platform that is otherwise so amazing. This issue comes up often enough that I feel the need to set aside a LARGE chunk of my time to create a FULL library of steel extrusions smaller than what Inventor offers. :smileyfrustrated:
    01-14-2013 11:10 AM in reply to: bhahn
    http://forums.autodesk.com/t5/Inventor-ETO-IdeaStation/idb-p/1231
    Active Member
    01-14-2013 11:41 AM in reply to: JDMather
    Idea station post submitted. Please +1 it if you've had this problem:
    http://forums.autodesk.com/t5/Inventor-IdeaStation/More-ANSI-sizes-in-Frame-Generator/idi-p/3752638
    01-14-2013 01:42 PM in reply to: bhahn
    While I am more "concerned" about the lack of the common 1"x1" HSS in the CC, I would agree with you.  Tubing/HSS sizes should start below 1.25".  I would also say that creating custom structural parts for the CC is easier said than done if you want to include proper formatting for BOMS and partlists.
    Rob
    *Pro
    sbixler
    01-14-2013 06:04 PM in reply to: JDMather
    JD, I think the link you want is Inventor IdeaStation not the ETO IdeaStation (whatever that is!).
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
