• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Mentor
    CelticDesignServices
    Re: Sketched Symbol Insert bug?
    04-11-2012 09:27 AM in reply to: cwhetten
    C,
    Yes, I was just about to post the hole size vs the symbol size issue (see attached....same holes, just changed the diameter from .25 to .125").
    Sure seems like a bug for sure.
    Jim
    Celtic Design Services, LLC
    Inventor/AutoCAD/Vault WorkGroups
    Always for hire - celticdesign01ATyahooDOTcom
    http://www.linkedin.com/pub/celticdesignservices-llc/51/610/398/
    Please use the Accept as Solution and Give Kudos functions as appropriate to further enhance the value of these forums.
    Go raibh maith agat (in other words...Thank you!)
    Please use plain text.
    Valued Mentor
    04-11-2012 09:47 AM in reply to: CelticDesignServices
    Bug report has been submitted.
    Scaling views up and down just to insert this (or any other affected) symbol is an unacceptable workflow as one can guess.
    Jim
    10-26-2012 05:36 AM in reply to: CelticDesignServices
    I have had the same problem for quite sometime now, and I have found a work-around that is a little easier to swallow.  The snapping problemseems to only occur if you try to snap to the center upon insertion.  If you insert the symbol into empty space first, then move it using the green grip, it will snap to the center, no problem, one small extra step.  At least it works in Inventor 2011.
     Hopefully this bug gets resolved!!
