• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Sketch lines won't associate
    63 Views, 1 Replies
    02-19-2013 06:30 AM
    When I am in sketch mode I can draw a rectangle and when I go back to dimension it it only adjusts that specific line and not the connecting lines.  Is there a setting or command to fix this?
    Please use plain text.
    Re: Sketch lines won't associate
    02-19-2013 06:38 AM in reply to: sjackson67
    Attach your file here.
    What do you have Constraint Persistance set to?
    What do you have Constraint Options set to?
    What version of Inventor are you running?
    Inventor Professional 2014 Edu 64-bit
