• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Blair Stunder
    Sketch in Weldment?
    256 Views, 6 Replies
    10-01-2008 11:26 AM
    In a standard IAM you can create a Sketch, but
    in a Weldment, you can't in the main IAM enviroment. Did something change, or
    was this functionality never there.
    IV2009-Pro Sp1
    Dell 670 dual Xeon -
    3.2
    3gb memory, SCSI320-15k rpm
    XP-Pro, sp3
    Quadro FX3400: Driver:
    174.06 Direct3D
    SpacePilot Rel V: 3.6.7 Dvr V: 6.6.1 Firmware
    3.12
    Please use plain text.
    *Blair Stunder
    Re: Sketch in Weldment?
    10-01-2008 11:33 AM in reply to: *Blair Stunder
    Work-a-round is to have a uncomsumed sketch, but
    this requires a separate IPT file.
    IV2009-Pro Sp1
    Dell 670 dual Xeon - 3.2
    3gb memory,
    SCSI320-15k rpm
    XP-Pro, sp3
    Quadro FX3400: Driver: 174.06
    Direct3D
    SpacePilot Rel V: 3.6.7 Dvr V: 6.6.1 Firmware 3.12
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    but in a Weldment, you can't in the main IAM enviroment. Did something change,
    or was this functionality never there.
    IV2009-Pro Sp1
    3.2
    XP-Pro, sp3
    174.06 Direct3D
    3.12
    *Loren Jahraus \(Autodesk\)
    10-01-2008 02:43 PM in reply to: *Blair Stunder
    Sketches are enabled when Preparations or Machining
    is active.
    Loren Jahraus
    Autodesk Inventor Product
    Design
    *Blair Stunder
    10-01-2008 03:48 PM in reply to: *Blair Stunder
    But you can't have a sketch in the main IAM
    enviroment the same as a standard IAM non-weldment
    IV2009-Pro Sp1
    3gb memory,
    SCSI320-15k rpm
    XP-Pro, sp3
    Direct3D
    Machining is active.
    Loren Jahraus
    Design
    10-01-2008 04:48 PM in reply to: *Blair Stunder
    I believe the sketches are restricted to those
    environments In elements because you can't create features at the top
    level. What are you using the sketch for? I can add this to our database, but it
    helps if I have documentation on the workflow it is supposed to
    support..
    Loren Jahraus
    Design
    Distinguished Contributor
    duncan
    10-03-2012 02:04 PM in reply to: *Loren Jahraus \(Autodesk\)
    Loren,
    I appriciate this is an old post, but I got a good reason to have a sketch in a weldment.
    To help place a work feature
    Take a hollow hemisphere
    Make a hole through the shell that is off-centre from the middle, but parallel to the centre line
    You have curves in all three dimensions, so placing work planes accurately become difficult
    I now need a work point that is in the centre of the hole and aligned with the outside of this hemispherical shell
    I also want to put it in with the least number of work features to keep the file size to a minimum.
    I would put a work axis down the hole and a work plane between the centre work plane and the one down the hole.
    Next I would put a sketch on the work plane a project the geometry
    Where the sketch geometry crosed the user work axis I would put a work point.
    I'm open to any better suggestions as well
    TIA
    Duncan Anderson
    "Humour is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad
    as what passes for ordinary living." {Terence "Spike" Milligan KBE (16 Apr 1918 – 27 Feb 2002)}
    New Member
    10-31-2012 01:48 PM in reply to: *Blair Stunder
    Sounds like the same thing I'm trying to do.
    Workflow is:
    Open weldment
    Create specific planes for nozzles on tank head ( for repositing on head later)
    Place tank head from standards library
    Start machining
    Create first cut for vessel inlet flange
    Create sketch on vent nozzle plane at desired angle
    This is to produce a hole cut thru the tank head (for locating the pipe/flange later)
    When trying to create an axis and point the workflow comes to a screeching halt
    Inventor 2013 will not allow me to perform those tasks
    This workflow is more desirous than copying/renaming the standard tank head just to make cutouts.
    Then placing that .ipt into a weldment.iam.  What would be the point of having a standard tank head if you can't perform these basic tasks.
