• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Sketch creation changes view
    129 Views, 2 Replies
    10-31-2012 05:04 AM
    I just installed the trial version of Inventor pro, 2013.  I'm having a problem with the view changing on creation of a sketch.  It goes to the home position.  The "Look at sketch plane on sketch creation" is un-ticked in options.
    Click on Component->Create.  Once the Component is created, click 2D Sketch.  View spins to the Home position.  This is really annoying.  I learned Inventor 2010 in school.  I don't remember this ever happening.
    If I select a plane from the browser prior to clicking the Create 2D Sketch, the view remains the same as expected.  This is only a problem if you want to create the initial sketch using a face of another part as the sketch plane. Is there an option I'm missing?
    Thank you
    Product Design Suite 2013 Ultimate
    Windows 7 64-bit
    Intel Core 2 Quad Q9300 2.5GHz
    8 GB RAM
    Nvidia GeForce 8800 GT
    Please use plain text.
    Distinguished Mentor
    ampster
    Re: Sketch creation changes view
    10-31-2012 05:44 AM in reply to: chipwitch2
    you haven't missed an option, you found one of the annoyances of Inventor.
    The trick is to rotate your view slightly before you start up the sketch command.  That should prevent it from rotating.
    Employee
    10-31-2012 07:03 PM in reply to: chipwitch2
    Thanks for reporting this issue to us. I can reproduce the case that view returns to home view when create sketch in components environment. I have filed an issue to internal team for investigation.
    Fred Chen
    SQA Engineer
    Quality Assurance Team
    Autodesk, Inc.
