Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Sketch creation changes view
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just installed the trial version of Inventor pro, 2013. I'm having a problem with the view changing on creation of a sketch. It goes to the home position. The "Look at sketch plane on sketch creation" is un-ticked in options.
Click on Component->Create. Once the Component is created, click 2D Sketch. View spins to the Home position. This is really annoying. I learned Inventor 2010 in school. I don't remember this ever happening.
If I select a plane from the browser prior to clicking the Create 2D Sketch, the view remains the same as expected. This is only a problem if you want to create the initial sketch using a face of another part as the sketch plane. Is there an option I'm missing?
Thank you
Windows 7 64-bit
Intel Core 2 Quad Q9300 2.5GHz
8 GB RAM
Nvidia GeForce 8800 GT
Re: Sketch creation changes view
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you haven't missed an option, you found one of the annoyances of Inventor.
The trick is to rotate your view slightly before you start up the sketch command. That should prevent it from rotating.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for reporting this issue to us. I can reproduce the case that view returns to home view when create sketch in components environment. I have filed an issue to internal team for investigation.
Fred Chen
SQA Engineer
Quality Assurance Team
