• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Sketch behavior has changed
    167 Views, 4 Replies
    11-26-2012 06:43 AM
    So all of a sudden my sketch behavior has changed and I can't firgure out why.  So here is what's happening:
    1)  Sketch lines are not being constrained to each other.
    2)  The center of a straight line no longer marked with a green dot (when I hover near it).
    3)  Extruding is a problem.  Open loops are found in simple sketches.
    4)  Sketches are being created as adaptive.
    I went into application options and setting and tried to see if anything had changed but I couldn't see anything different.  The only thing that I had done different in the last day or two was copy an AutoCAD sketch and paste it into a new .ipt file. Other than that, nothing else is different.  This is very confusing.  Does anyone know why this is happening?  I must have zigged when I should have zagged?  Help!
    Thanks.
    Steve Frey
    Inventor 2013
    Windows 7 Professional 64-bit SP1
    HP EliteBook 8470w
    Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
    Memory: 16 GB
    AMD FirePro M2000
    3D Connexion SpacePilot
    Please use plain text.
    *Pro
    jletcher
    Re: Sketch behavior has changed
    11-26-2012 07:54 AM in reply to: SteveFrey
    Have you check the Constraint options?
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    11-26-2012 09:02 AM in reply to: SteveFrey
    Let me guess (since you left out this critical information), you are using 2010 and clicked Constraint Persistence (thinking it was Perpendicular constraint) and turned off constraint persistence.
    Never mind, I see you are using 2013 http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2013-crashes-during-break-out-view-creation...  or are you?
    Inventor Professional 2014 Edu 64-bit
    11-26-2012 09:35 AM in reply to: jletcher
    I think that was it.  I don't remember un-checking them.  Wierd.  Thanks.
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    11-26-2012 09:36 AM in reply to: JDMather
    Oops.  Yes, 2013.  I think jletcher answered it.  Thanks!
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
