Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Sketch-Tex tBox Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello mates,
I need to know is there a way to change TextBox Text Style from default to some thing else?????
Please it very confusing and like a maze to change it???
Please help....
Inventor Applications Engineer
If my solution seems to remedy your problem, please press the Accept Solution button, Some KUDOS -
Re: Sketch-Tex tBox Style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You need to create your own DEFAULT-ISO template.
Open a random IDW file, then open the stylemanager from the Manage Tab. Select a text-style and create an New style. Name the new Style DEFAULT-ISO and make your changes in this style. Inventor will use this style in the sketch.
Rob.
Software in use: Inventor 2013, SolidWorks 2011
Also experience with: Solid Edge untill ST4,
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello Rob,
I have tried that before posting and did today as well but no luck mate...
Went to default idw template, added new text style and opend a part and did sketch and when I am entering a text box is is still Default ISO.
Can you show me If you had any luck with it or Am i Missing something here?? in doing that??
correct me if I am wrong...
Best regards
AD
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You need to create a new text style called DEFAULT-ISO, and it has to be EXACTLY the same in terms of characters, caps, etc. You also need to make sure your style library is read-write, and once you've created it save it to the style library.
You're trying to mess around with stuff that for one reason or another Autodesk doesn't want you messing with. There's just no way to accomplish what you want without doing it, though.
The whole process is set out pretty well here.
___________________________________________________________
Product Design Suite Ultimate 2013
Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A new DEFAULT_ISO ??? where it shold be created ?? In Styles ot Text or Object Defaults ???? I did in Text and no luck my friend..
Can you please tell me more??? Procedures....
Very Helpful, thanks mate,
AD
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Look at the link in my last post, the guy that wrote that up did a thorough job explaining it.
Also, if you call it DEFAULT_ISO it won't work. Gotta have the characters EXACTLY the same.
One other caveat: in what you're doing, there's no way to set different styles, so if you have a couple different styles you want to use with sketched text, you're SOL. The only thing you're going to be able to do is go back and re-do the whole style hack to make it a different default, or do manual changes for everything that needs to be different. Pick the one you use the most and set it, then make manual changes for variations.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Looked at the link my friend... So the only way is to edit the style to changing text style parameters. But not to create another style.
If you see this Link from Inventor Help It says we can choose style by clicking dropdown button.
It says Click arrow and select from list of available style..
what do you think of that???
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think you've uncovered a flaw in the documentation, my friend, because that is most certainly incorrect information.
Just go back to the link I provided and try it. I promise you, it works. I used that technique to edit the sketch text defaults on my machine a couple months back.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am Convienced with your Info and got the DEFAULT-ISO in Text Style of idw and it is working fine (with Default style).
But I looking to get an option to have another style, a couple. but NOO LUCK...
May be I should point it to Autodesk.
Will Update you with that in thread.
Regards My Friend.
AD
If my solution seems to remedy your problem, please press the Accept Solution button, and Some Kudos -
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Post your suggestion here: Inventor IdeaStation
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
