I have a simple nameplate I wish to add text only to from the parameters. My part model is a simple rectangle extrude with a stetch on top incorporating text only which is linked to the parameters. I do not wish to add any feature to the text. However if the parameter number is changed then the sketch text does not update accordlingly.
I have tried every ilogic update and nothing works. The only 2 ways for the text to update is 1: to left click on the text and try to move the text. It won't move obviously as it is constrained but it updates. 2 :The only way that will work through an ilogic rule is to change it's thickness followed by a "RuleParameterUpdate" then set it thickness back to what it should be.
To confuse matters if the part is put onto a drawing sheet and I make the sketch visible the drawing will show the text as updated before any update attemps are done on the actual part.
I have attached the part for consideration where you have to run the Ilogic rule "SETUP" to update the text.
Cheers
