• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Simulating Torque in Autodesk Inventor or Autodesk Multiphysics
    145 Views, 1 Replies
    04-27-2012 01:58 PM
    Hello Everyone,
    I'm currently modeling a screw for a spinal implant for my Senior Design project and I am trying to analyze the amount of torque that it can withstand before breaking. I would like to simulate the screw being inserted into bone and see the pressure that the thread undergoes, however, I've only been able to apply forces along the Z and Y axis.
    I would appreciate any help regarding this issue. Thank you very much for your time and help.
    Please use plain text.
    Employee
    Re: Simulating Torque in Autodesk Inventor or Autodesk Multiphysics
    04-27-2012 05:47 PM in reply to: xalan001
    Hi xalan001,
      You can apply a torque load instead of a force, it is labeled as moment.
      I'm not that familiar with bone material, but I assume that the screw threads do not undergo plastic deformation.  It is non-trivial to do a non-linear analysis on threads...as only 2-4 threads hold most of the load at least when we're dealing with metal on metal.
      If you need to include the compliance of bone, I suspect bone may have a non-linear stiffness [Edit: or it is considered a brittle material].  Therefore, this may require Autodesk Mechanical simulation.
    Hope this helps...
    *Please press the 'accept as solution' button if this thread answers your question, so others can quickly benefit*
    Hugh Henderson
    Simulation QA Engineer
    DLS (Simulation and Material Sciences)
