• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Valued Contributor
    Sign in
    161 Views, 4 Replies
    10-11-2012 10:53 PM
    I've been sending crash reports for some time, but so far without much response. Just wondering if my problem sounds familiar and if someone else has a solution.
    Problem:
    Start IV, hit 'sign in' at the top right corner (cloud 360) => crash
    Start IV, create a part, go to environments, click optimize => sign in dialog appears and is followed by a crash seconds later.
    I really like to use the opimization function that I used in 2012 a couple times, but it's impossible to get it started. Any help is much appreciated as my frustration is growing rapidly.
    Cheers!
    Joeri
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: Sign in
    10-14-2012 07:27 PM in reply to: joerituijn
    Are you facing this issue on 2013. Can you provide what product you have. (eg : Factory design suite 2013).
    Also send us a screenshot of the error that you receive while inventor crashes.
    Please provide us the email address you have used to submit the reports.
    Did you manage to login and download the patch. If not, you can download from subscription center. More info can be found below.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17911235&linkID=16831209
    Looking forward to your update.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Autodesk, Inc.
    Valued Contributor
    Re: Sign in
    10-14-2012 07:56 PM in reply to: VinodBalasubramanian
    1. I’m using Autodesk Product Design suite 2013
    2. I never saw any patch notification. Wasn’t that just for 2012?
    3. I have send you my email adress through a PM.
    4. I don’t receive an error, I just get the crash screen that sends the error report. Before the crash, I see this screen:
    I just created another crash report.
    Cheers,
    Joeri
    Product Support
    Re: Sign in
    10-16-2012 08:27 PM in reply to: joerituijn
    Please try the following suggestion and you can download the Inventor Optimization manually by logging into Subscription center. You can also login to 360.autodesk.com and download it as shown in screenshot below.
    http://beinginventive.typepad.com/being-inventive/2012/01/autodesk-suites-using-environments-tab-opt...
    Autodesk Support
    Autodesk, Inc.
    Valued Contributor
    Re: Sign in
    10-16-2012 09:05 PM in reply to: VinodBalasubramanian
    Thanks for the reply, however, i work with 2013 not with 2012 as mentioned before. Both suggestions only apply to 2012. I have logged a support request, thanks for your time.
