Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Shell Command Help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have been working on a project, and some of the dimensions have changed so I decided to remake the parts from scratch. But when I tried to use the Shell command on one of my new parts, I get the error "The attempted Shell operation would require a large topology change. Try with a smaller thickness."
I've tried smaller thicknesses, but nothing works. I'm just confused because it is very similar to the old part that I Shelled without a hitch.
I've attached both parts. I'm trying to Shell the inside of the part, through the circular opening. Any help or suggestions would be appreciated.
Elizabeth
Using Autodesk Inventor 2013
Re: Shell Command Help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you post a pic I don't have 2013 loaded here.. but try a thicker shell to see if that works. Sometimes small in a shell command error means thicker. So if you had .125 try .187 not .100....
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks a lot, making it thicker worked!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You didn't indicate your desired shell thickness on the second part.
What is (8-5.136125959)/2=?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
elizabeth.dawe wrote:Thanks a lot, making it thicker worked!
You better check your results and verify the design intent. Do you understand the significance of my first question?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, I don't understand exactly what you're saying
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What would be the maximum wall thickness you could have with this area shelled?
(when you go over that max thickness - it works, but it isn't shelled in this thin area above the two green lines)
In your first part it is shelled in this area. Which solution do you really want?
BTW - you are still duplicating dimensions and not using symmetry about the origin. You might read this document http://home.pct.edu/~jmather/SkillsUSA%20Universit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I realized that afterwards. I'm going to change the thickness and some dimensions.
When I learned how to use SolidWorks, I was taught to start at the origin and go from there in one of the quadrants, not for symmetry about the origin. I guess old habits die hard.
I'm just starting to use Inventor so that document is very helpful. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I learned how to use SolidWorks, I was taught ...
You were taught incorrectly. The proceedure is the same in SolidWorks and Creo (Pro/E).
It is a question of using the "best" and "most efficient" technique, not right or wrong.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok...
