• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Sheetmetal contour roll flat pattern
    248 Views, 4 Replies
    01-21-2013 05:25 AM
    Inventor 2013-I'm working on a sheet metal cover using contour roll and I find when I dimension the flat pattern that radii that should be the same are not. Can someone tell me if my approach is fundamentally flawed? I  tried making this part out of one 220 degree contour roll and I found when dimensioning that the center points of the arcs are not symmetric as expected. I then used two contour rolls to create the part basing the second contour roll on the first contour roll sketches and I still have the same issues. Any thoughts would be appreciated. Thanks
    Please use plain text.
    blair
    Re: Sheetmetal contour roll flat pattern
    01-21-2013 08:41 AM in reply to: kenbig
    You most likely need to read up on Bend Allowance Factor. This will vary according to the type of bending procedure used. The Flat-Layout length is determined by the neutral axis through the material. Not quite the center line of the product.
    The attached spread sheet might help you out.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Active Member
    01-21-2013 09:15 AM in reply to: kenbig
    Check this example.
    Active Member
    01-21-2013 09:28 AM in reply to: kenbig
    thank you for you quick reply, I took a look at the spread sheet and  it looks like I have a lot to understand in order to properly apply all possible variables to my project. In the mean time while I try to figure this all out and understand the spread sheet, does it make sense that these variables create the problems in symmetry that I see in the flat pattern dimensions?
    Active Member
    01-21-2013 09:33 AM in reply to: TheCADWhisperer
    thank you for you quick reply and example, your solution sure is elegant compared to my attempt. now I have to go back and see if it fits my mating part and if I can create the remaining parts to the cover in a similar fashion, thanks again.
