• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Clark, George
    Sheet metal and step files
    64 Views, 3 Replies
    11-20-2002 04:56 AM
    I have an assembly that was made in Pro-E and sent to me as a step file. I
    thought I had it made because the first part I opened I clicked on a face
    and it unfolded. This was the only part that this worked with though. The
    funny thing is that the thickness on this part was .25, the same as the
    radius. This worked with the default settings at .12 thickness. Now I try
    some parts with a thickness of .12 or .1196 to be exact and they won't
    unfold. Is this something that can be done easily in IV5.3 or will I need
    and add-on. As you can probably tell I'm inexperienced with Sheet Metal.
    George Clark
    Please use plain text.
    *Keller, Kent
    Re: Sheet metal and step files
    11-20-2002 04:59 AM in reply to: *Clark, George
    Are any of the step files small enough to post to customer files?
    Kent
    Member of the Autodesk Discussion Forum Moderator Program
    "George Clark" wrote in message
    news:CC485E6AF6FC710D7F7142A8439BDBEB@in.WebX.maYIadrTaRb...
    *Clark, George
    Re:
    11-20-2002 05:18 AM in reply to: *Clark, George
    I think I see the problem. The thicknesses are inconsistent on the parts I
    can't unfold, ie .120 on the flat and .1196 on the flange. The problem part
    is called tie_bar. The MTG_Foot I had no problems with. They are posted
    under sheet metal.
    George
    "Kent Keller" wrote in message
    news:smileyvery-happy:401C89FBF19E4080B1F29E95F8FFAA2@in.WebX.maYIadrTaRb...
    > Kent
    I
    face
    *Keller, Kent
    Re:
    11-20-2002 11:22 AM in reply to: *Clark, George
    George
    Been that kind of day... sorry for not getting back to you sooner. Actually
    not much to say... I think you figured it out, it appears to be a accuracy
    export problem. I haven't dealt with ProE much, but if that is where it
    came from I keep hearing people say they have to turn up the accuracy in Pro
    before exporting.
    Kent Keller
    http://www.MyMcad.com/KWiK/Mcad.htm
    news:01CC867A9A8E08F1E6DC709086C8E9B7@in.WebX.maYIadrTaRb...
    part
    > under sheet metal.
    > Thanks,
    > George
    > > Kent
    file.
    > I
    > face
