• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Mentor
    Re: Sheet metal Problem
    11-12-2012 07:59 AM in reply to: JDMather
    Here's my attempt, at least the first half. Not perfect, but might be close enough after some tweaking.
    Please use plain text.
    11-12-2012 03:26 PM in reply to: aaddekrom
    I worked out a solution today.  I will post it tomorrow if I remember.
    11-12-2012 07:06 PM in reply to: JDMather
    I could not find a way other than face-by-face.
    The attached was done in student version - so examine the technique and then delete.
    Pull down the red End of Part marker step by step.
    Active Member
    aaddekrom
    11-12-2012 11:57 PM in reply to: JDMather
    This is great ! Just faces.
    Thank you very much.
    Active Member
    aaddekrom
    11-13-2012 12:11 AM in reply to: rdyson
    Thanks for your help, it looks ok, but JDMathers solution is more straightforward.
