• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    ENRAD
    Sheet metal/Flat pattern screews up coordinates.
    127 Views, 5 Replies
    03-15-2012 04:12 AM
    Why is it, when I go to Flat Pattern/export to DXF that everything ends up upside down.
    I have part where it is important that the correct side is faced upp, (brusched steel).
    When i Export it to dxf, it is upside down, and the bruched facefacing down.
    Please use plain text.
    *Expert Elite*
    Re: Sheet metal/Flat pattern screews up coordinates.
    03-15-2012 04:18 AM in reply to: ENRAD
    You can flip before exporting.
    Attach your file here.
    Valued Contributor
    ENRAD
    03-15-2012 04:50 AM in reply to: JDMather
    Ok, found that, but why cant it be correct from the beginning?
    *Expert Elite*
    Curtis_Waguespack
    03-15-2012 06:19 AM in reply to: ENRAD
    Hi ENRAD,
    As JDMather mentioned you can adjust the flat pattern orientation before exporting it as described at this link:
    http://inventortrenches.blogspot.com/2011/05/edit-flat-pattern-orientation.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Contributor
    ENRAD
    03-15-2012 06:41 AM in reply to: Curtis_Waguespack
    Yes I understand that, But, if I have say 300 parts to export, thats nearly 1000 extra mouse-clicks to do, so why cant Inventor do it correct in the first place.
    Active Contributor
    03-15-2012 06:52 AM in reply to: ENRAD
    Pick your face side before you create the flat pattern. You may want to rotate your flat pattern after, but at least your "good" side will be facing you.
    Donald L.
    Inventor Product Design Suite Premium 2013 SP1.1
    Windows 7 Professional - 64 bit
    HP h8-1380t - i7-3820 @ 3.6 GHz
    10 Gb
    AMD Radeon HD7950 3Gb
