• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    j.vanderheijden
    Re: Sheet Metal styles
    12-11-2012 11:33 AM in reply to: japike
    I have made a rule to control the overlap who isn't work all the time.
    currentStyle = SheetMetal.GetActiveStyle()
    If currentStyle = "Inteco_0.7" Then
       Parameter("overlap1") = 0.8 ul
    Else If currentStyle = "Kemi" Then
        Parameter("overlap1") = 0.1 ul
    End If
    InventorVb.DocumentUpdate()
    The parameter "overlap1" has to control the overlap in the Corner Seam.
    But i have to change first something in the rule and then when i change the style it works one time.
    Do i miss something?
    Mvg Jos
    Your drawings are only as good as the symbols that complete them...
    Please use plain text.
    j.vanderheijden
    12-11-2012 12:52 PM in reply to: j.vanderheijden
    I know the problem.
    Everytime i change the style i have to right click the rule and give run rule.
    Why isn't that go automatic when i change the style?
    Mvg Jos
