• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    SeanFarr
    Accepted Solution
    Sheet Metal - cut across bend
    155 Views, 2 Replies
    12-20-2012 08:03 AM
    I have a sheet metal door with a little bracket that gets welded to the inside lip through a cut-out in the face of the door. (see assembly)
    I can't get the cut-out to line up flush with the inside lip of the door, as that is where the brackets gets welded to. the current aseembly is set-up the way I want, but I can't get a flat pattern on the door, becasue of the cut going across the bend.
    I have checked off the "cut across bend" in the cut dialogue box, but this leaves a small (~1/32) lip in the cut-out and runs interference in the placement of the bracket.
    Any ideas?
    Sean
    Inventor Pro Suite 2013
    Sean Farr
    Product Designer at TESInc.ca
    Inventor Professional 2014 - AutoCAD Electrical 2014
    Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
    240GB SSD | nVidia GTX 670 4GB - 314.22
    Please use plain text.
    Valued Mentor
    japike
    Re: Sheet Metal - cut across bend
    12-20-2012 09:54 AM in reply to: SeanFarr
    If you want the cut to be flush with the inside then the cut should remove the entire bend in that area. See the attached part.
    Peace,
    Jeff
    Inventor 2013
    SeanFarr
    12-20-2012 10:10 AM in reply to: japike
    Makes sense, if I am going to cut across the bend, why not cut across the entire bend.
    thanks!!
    Sean
    Sean Farr
