Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Sheet Metal - cut across bend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a sheet metal door with a little bracket that gets welded to the inside lip through a cut-out in the face of the door. (see assembly)
I can't get the cut-out to line up flush with the inside lip of the door, as that is where the brackets gets welded to. the current aseembly is set-up the way I want, but I can't get a flat pattern on the door, becasue of the cut going across the bend.
I have checked off the "cut across bend" in the cut dialogue box, but this leaves a small (~1/32) lip in the cut-out and runs interference in the placement of the bracket.
Any ideas?
Sean
Inventor Pro Suite 2013
Product Designer at TESInc.ca
Inventor Professional 2014 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.18
Re: Sheet Metal - cut across bend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you want the cut to be flush with the inside then the cut should remove the entire bend in that area. See the attached part.
Jeff
Inventor 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Makes sense, if I am going to cut across the bend, why not cut across the entire bend.
thanks!!
Sean
