• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    rdiamond113
    Accepted Solution
    Sheet Metal controlled through iLogic
    264 Views, 8 Replies
    03-04-2013 01:56 PM
    Does anyone know a way or a code to physically change the sheet metal defaults using iLogic code, I want to change parts in my assembly without opening each individual part and changing it there. Please help!
    Inventor 2013 SP-1.1 Update 2, Windows 7, 64 bit
    "Pushing the envelope, just to watch it bend"
    Please use plain text.
    Product Support
    innovatenate
    Re: Sheet Metal controlled through iLogic
    03-05-2013 05:21 PM in reply to: rdiamond113
      Dim oAssyDoc As AssemblyDocument
      oAssyDoc = ThisApplication.ActiveDocument
      Dim oDoc As Inventor.Document
    'Add Input Box to retreive value here
      Dim oTargetTHK As Double
      oTargetTHK=25.4
      'Check all referenced docs
      For Each oDoc In oAssyDoc.AllReferencedDocuments
        'verify document type (we are interested in metal sheets only)
        If oDoc.ComponentDefinition.Type = 150995200 Then
    		Dim oSheetMetalCompDef As SheetMetalComponentDefinition
    		oSheetMetalCompDef = oDoc.ComponentDefinition
    		' Override the thickness for the document
    		oSheetMetalCompDef.UseSheetMetalStyleThickness = False
    		' Get a reference to the parameter controlling the thickness.
    		Dim oThicknessParam As Parameter
    		oThicknessParam = oSheetMetalCompDef.Thickness
    		' Change the value of the parameter.
    		oThicknessParam.Value = oTargetTHK
    	Else
    Next
    I was able to put the above code together after reviewing the example titled 'Sheet Metal Thickness Editing API Sample' from the Help pull down menu > Community Resources > Programming Help. Seems to work on the few simple examples I've tested.
    Hope this helps.
    Nathan Chandler
    Product Support Specialist
    Product Support Americas
    Autodesk, Inc.
    rdiamond113
    03-06-2013 06:46 AM in reply to: innovatenate
    I get an error when i copy this code into it's own rule that says "Error on Line 10 : 'For' must end with a matching 'Next'.
    Am I doing something wrong or do I need to change anything in the code to personalize it?
    Thank you
    *Expert Elite*
    Curtis_Waguespack
    03-06-2013 07:23 AM in reply to: rdiamond113
    Hi rdiamond113,
    Just a guess but did you happen to miss the last line when you copied the code?
    The last line, Line 29,  contains the missing Next statement.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    rdiamond113
    03-06-2013 07:42 AM in reply to: Curtis_Waguespack
    I added it to my assembly and when I ran the rule I received a ton of errors. I'm using this to change the sheet metal type of a round column cover consisting of 4 quarter "skins". I'm not sure what type of parts you're using this code with but some of the errors I got had to do with basically rebuilding the skin and what not, like bend radius errors and sketch geometry errors
    *Expert Elite*
    Curtis_Waguespack
    03-06-2013 08:05 AM in reply to: rdiamond113
    Hi rdiamond113,
    It worked for me using an assembly with 3 sheet metal parts and 2 non-sheetmetal parts.
    I made a couple of modifications, by adding an update statement and adding an input list, but other than that it's the same.
    I hope this helps.
    Curtis
    'get user input
    'oTargetTHK= InputBox("Enter Thickness", "iLogic", "0.2")
    'create list of thicknesses
    dList = new double(){0.1,0.2,0.3}
    'get user input from list
    oTargetTHK = InputListBox("Select a Thickness", dList, dList(0), "iLogic", "Thicknesses")
    	Else
    Next
    InventorVb.DocumentUpdate()
    rdiamond113
    03-06-2013 09:15 AM in reply to: Curtis_Waguespack
    Okay I got it to work, the only issue I have now (LOL) is setting my specific sheet metal thickness, I changed where you had the thicknesses listed and found that it was setting the thickness to half what I ented in the list. how should I enter my standard sheet thicknesses?
    rdiamond113
    03-06-2013 10:12 AM in reply to: Curtis_Waguespack
    I just realized the output from the code is metric, how can i change it to Inches?
    *Expert Elite*
    Curtis_Waguespack
    03-06-2013 10:38 AM in reply to: rdiamond113
    Hi rdiamond113,
    Internally Inventor works with centimeters as the default unit, to adjust your input to inches can multiply your input by 2.54 as shown in this example.
    I hope this helps.
    Curtis
    'get user input
    oTargetTHK= InputBox("Enter Thickness", "iLogic", "0.2")*2.54
    	Else
    Next
