• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Sheet Metal Rules Inventor 2013
    957 Views, 3 Replies
    04-26-2012 10:08 AM
    Getting materials set up is turning into a pain with the "improvements" they made to them in 2013.  Right now my issue is with sheet metal rules. They all have the materials set to "generic". I can go in to the styles and standards editor and change it to the specific material I want to use but when I then right click on the sheet metal rule the option to "save to styles library" is grayed out so next time I want to use the same sheet metal rule, I have to go through the process of changing the material again.
    Is there a different way of saving sheet metal rules now?
    Please use plain text.
    Product Support
    Dennis.Ossadnik
    Re: Sheet Metal Rules Inventor 2013
    05-04-2012 07:52 AM in reply to: prachu
    Hi prachu,
    please try this workflow:
    - open Styles Editor and make your changes to the material in Sheet Metal Rule
    - Leave the dialog and save your changes
    - now go to the Ribbon Manage - Styles and Standards
    - click on Save
    --> Now you should be able to save your changes to the library.
    (You need read-write in your Style Library.)
    Please use the button "Accept as Solution" if it works.
    Dennis Ossadnik
    Support Specialist
    Product Support
    05-04-2012 08:25 AM in reply to: Dennis.Ossadnik
    This method appears to work so far but I'm not really sure why. Editing the style library it did say Read/Write already in the top bar before doing this.
    Distinguished Contributor
    MRanda
    05-26-2012 10:23 AM in reply to: prachu
    I have been working for hours now with grayed out options that should be there and other goofy behavior for Inventor Materials and Appearances in 2013. Im not sure why they would deliver a product as jacked up as this!  Inventor always was user unfriendly in the materials and colors area ---now it's just a total mess.
    Will this be fixed? I have the same grayed out save option, and cannot save local styles whatsoever. I can save to the style library, but need local styles to show the differance ..... or are local styles now a thing of the past?
    Mark randa
    OpenDesignProject.org
    Self built computer with;
    Quad core processor
    16 gigs ram
    Raptor Raid main drives
    2 x 1TB Caviar Black storage drives local
    2 x 1TB Caviar Black storage drives network backup
    Main Software;
    Product Design Suite Premium
    Windows 7 Home Premium
    Website;
    Applied Design Intelligence
    http://applieddesignintelligence.com/
