Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Schumacher, Ken
Re:
Options
- Highlight
- Email to a Friend
11-12-2002 05:36 AM in reply to:
*Schumacher, Ken
Ok. Tell me this isn't bizarre.
If I go to Tools, Application Options, Text Appearance,
and change from Arial back to the default of Tahoma, it works fine.
Hello Autodesk?????
"Ken Schumacher" wrote in message
news:232D46D844B928EA093535570ADADCB3@in.WebX.maYI adrTaRb...
> Hey Mike.
> I can do what your saying, but it won't accept in for a depth.
> Just for yucks, I tried it for the diameter, and that worked, but not for
> the depth.
> Thanks for the tip though.
> -Ken
> "Mike Maenpaa" wrote in message
> news:8DAF52FC573019B25225713CA936E8AB@in.WebX.maYI adrTaRb...
> > Highlight the value, then RMB (Right Mouse Button) and select List
> > Parameters, then select Thickness.
> > HTH
> > Mike
> > news:7A731BB62D352F23FB63494BC94D74FA@in.WebX.maYI adrTaRb...
> > > Well I just loaded 6, and working on my very first part. A sheet metal
> > part.
> > > In 5.3 when defining the depth of the hole, you were able to type in
> > > "Thickness"
> > > In 6.0 all you can type in is "Thickne"
> > > Is this a bug?
Hello Autodesk?????
"Ken Schumacher"
> Hey Mike.
> the depth.
> -Ken
> "Mike Maenpaa"
> > HTH
> > Mike
> > "Ken Schumacher"
> > part.
> > > "Thickness"
> > > Is this a bug?
*Dotson, Sean
Re:
Options
- Highlight
- Email to a Friend
*Schumacher, Ken
That has to be in the running for oddest bug...LOL
____________________
Sean Dotson
http://www.sdotson.com
...sleep is for the weak...
news:B5DF7EDF82665C1E1FA7BF45C304855A@in.WebX.maYI adrTaRb...
> Hello Autodesk?????
> > Hey Mike.
for
> > the depth.
> > -Ken
> > > HTH
> > > Mike
metal
> > > part.
> > > > "Thickness"
> > > > Is this a bug?
Sean Dotson
"Ken Schumacher"
> Hello Autodesk?????
> "Ken Schumacher"
> > Hey Mike.
for
> > the depth.
> > -Ken
> > "Mike Maenpaa"
> > > HTH
> > > Mike
> > > "Ken Schumacher"
metal
> > > part.
> > > > "Thickness"
> > > > Is this a bug?
*DJSpaceMouse
Re:
Options
- Highlight
- Email to a Friend
11-12-2002 05:55 AM in reply to:
*Schumacher, Ken
Anymore, as Jane's Addiction said, "Nothing's shocking."
> Hello Autodesk?????
> > Hey Mike.
for
> > the depth.
> > -Ken
> > > HTH
> > > Mike
metal
> > > part.
> > > > "Thickness"
> > > > Is this a bug?
"Ken Schumacher"
> Hello Autodesk?????
> "Ken Schumacher"
> > Hey Mike.
for
> > the depth.
> > -Ken
> > "Mike Maenpaa"
> > > HTH
> > > Mike
> > > "Ken Schumacher"
metal
> > > part.
> > > > "Thickness"
> > > > Is this a bug?
Re:
Options
- Highlight
- Email to a Friend
11-13-2002 02:21 AM in reply to:
*Schumacher, Ken
Ken,
I've just tried this on IV5.3 and 6.
It worked for thickness and diam.
Mike, Thanks for tip.
B. Vaintroub
Designer
B. Vaintroub
Designer
Re: Sheet Metal Holes
Options
- Highlight
- Email to a Friend
11-13-2002 02:31 AM in reply to:
*Schumacher, Ken
BSW
Another way, we have created user parameter "t" in SM template with equation "thickness",
so in hole dialog we are typing just "t" instead of "thickness"
B. Vaintroub
Designer
B. Vaintroub
Designer
*Cross, Gary
Options
- Highlight
- Email to a Friend
11-13-2002 04:49 PM in reply to:
*Schumacher, Ken
In my experience, it looks likeIV variable (parameter) input is case
sensative. I kept inputing what I knew was correct & it didn't work until I
got the case (caps & lower case) right. Did anyone else notice this or am I
in the Twilight Zone? (BTWForest Whitaker is pretty good on that new
show -Rod Sterling's a tough act to follow).
Gary
gcross@crossdesign.com
part.
> "Thickness"
> Is this a bug?
Gary
"Ken Schumacher"
part.
> "Thickness"
> Is this a bug?
*Keller, Kent
Re:
Options
- Highlight
- Email to a Friend
11-13-2002 11:05 PM in reply to:
*Schumacher, Ken
I believe Inventor has always been case sensitive.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Gary Cross" wrote in message
news:2FB2226092C92ED6E6F651BEC54EA9AB@in.WebX.maYI adrTaRb...
I
I
Kent Keller
"Gary Cross"
I
I
