• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Mentor
    jeanchile
    Accepted Solution
    Sheet Metal Flat Pattern Has No Solid/Object?
    115 Views, 3 Replies
    03-08-2012 07:56 AM
    Hello All,
    First, I feel obligated to remind everyone that I do not use the sheet metal tools in IV all that often so I fully expect that I have done something completely wrong but I can't figure out what it is so I kindly beg you all for help.
    I have a sheet metal part that in the folded part view looks like this:
    In flat pattern view (and any subsequent flat pattern drawing) it looks like this:
    What have I done to deserve this?
    Inventor Professional 2013 (SP-1.1), Product Design Suite Ultimate
    Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (314.07), Space Pilot Pro (3.16.1)
    Laptop: Intel Core 2 Duo T9600 @ 2.8GHz, 8.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTS 160M (314.07), SpaceNavigator (3.16.1)
    Please use plain text.
    *Expert Elite*
    MariaManuela
    Re: Sheet Metal Flat Pattern Has No Solid/Object?
    03-08-2012 08:16 AM in reply to: jeanchile
    First when i open the part  i was notified that your ipt depends of a AP-20 GAGE - LAYOUT SKETCH-WEST.ipt.. Same happens there??
    Ok...No problem because i click on SKIP and i get the part anyway.
    Yes....same happens here in Inventor 2012.
    So....i Deleted the Flat Pattern and create a new one and get the immediately what you want.
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    Valued Mentor
    jeanchile
    03-08-2012 08:27 AM in reply to: MariaManuela
    My apologies, I actually forgot that the lengths of these were derived from a layout sketch I did. I should have attached that part.
    Secondly, thanks for the help. I didn't know you could delete a flat pattern actually :smileyembarrassed:. I don't use these tools often. Anyway, that did the trick, I appreciate it immensely!
    Active Member
    03-09-2012 12:38 AM in reply to: jeanchile
    This happens to me sometimes too. I don't know why. By deleting the flat pattern it also deletes the view on your IDW. Edit the flat pattern and allign it again will fix the flat pattern too, without deleting the view on the IDW.
    Gr. Nick
