• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Sheet Metal Flange only on partial edge
    189 Views, 1 Replies
    12-14-2012 06:25 AM
    How can I define the length of a flange in a sheet metal part? In other words, I would like a flange to run a definitive length along the edge of a part, not the entire edge of a part.
    I apologize if this has been asked before. I did a brief search of the forum and could not find a solution.
    _____________________________________________________________
    Autodesk Product Design Suite Ultimate 2013 | Windows 7 Professional 64 bit, SP1
    Dell Precision T7600 | Two (2) Intel Xeon CPU E5-2630 @ 2.3GHz (12 cores, 24 logical processors) | 32 GB RAM
    Please use plain text.
    Re: Sheet Metal Flange only on partial edge
    12-14-2012 06:27 AM in reply to: j_berry
    Attach your file here.
    Expand the dialog box and set Width or desired Offset distance from each end.
