• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Caldwell, Larry
    Re:
    11-10-2002 03:26 AM in reply to: *Caldwell, Larry
    Thanks Jeff, I'll give it a look.
    The only heavy plate was the deck plate. It was like 1" to maybe 1.5", hard
    to remember really even though I usually got the job of burning them in and
    flushing the weld bevel so they could be welded to the mating section. The
    skin was at least 1/4 but maybe 3/8. Sorry I'm so foggy about it.
    ~Larry
    "Jeff Howard" wrote in message
    news:3E5865D4D954F83BB96FC449F981F68C@in.WebX.maYIadrTaRb...
    > Hi, Larry.
    > Sorry, I left out the "how to get into MDT" part. The command is IGESIN.
    > There are good and bad surfaces superimposed, so turn off or freeze the
    layers
    > you don't want visible. If that doesn't work and you are interested, I
    can
    > post or email some jpg's.
    > Profile weight.... referring to the loft dialog (in IV6) Conditions -
    > Weight. It's value must not be the reason you see the error. I guess it
    can
    > be generated when lofting between mulitple profiles, but an example
    doesn't
    > come to mind. I may be misinterpreting what the error message is telling
    us,
    > too (assuming it's not picked by a random number generator ). Any how,
    if
    > you'll post one when you come across it, I'll see if I can offer an
    > explanation for it.
    > Maintain value... same thing as the profile weight.
    > How thick were the plates?
    > Jeff
    Please use plain text.
    *Caldwell, Larry
    Re:
    11-10-2002 03:33 AM in reply to: *Caldwell, Larry
    I'm sure things are much different now Kent ... noth'n like when we were
    kids, eh? Ever remember staring at a test pattern wondering if any
    programs were going to come on?
    ~Larry
    "Kent Keller" wrote in message
    news:E23718A65BF5A8B835143DDBA35261B9@in.WebX.maYIadrTaRb...
    > I had read this a while back in the Fabricator magazine. It doesn't get
    > into to much detail, but it is interesting non the less. It sounds to me
    > they panels are fully formed now days before being welded (if I remember
    > right....didn't read the whole article)
    > Anne could probably shed some light on this for us 8^)
    http://www.thefabricator.com/xp/Fabricator/Articles/Fabricating/Fab02/02web4
    > 99.xml
    > Kent Keller
    > Member of the Autodesk Discussion Forum Moderator Program
    > http://www.MyMcad.com/KWiK/Mcad.htm
    > "Larry Caldwell" wrote in message
    > but I think, for the most part,
    > > the skin started out as plane ol' flat plate. The welders would weld it
    in
    > > place on one end and weld some pad-eyes on beside the location of a rib.
    *Caldwell, Larry
    Re:
    11-10-2002 03:59 AM in reply to: *Caldwell, Larry
    Figured it was a command-line deal. That is an excellent demonstration of
    what happens. Much easier to see in MDT. I'm going to go back and mess with
    that a bit. Thanks Jeff! I assume I could take whacked surfaces like that
    from Inventor, save them as igs and go look at them in MDT. Cool!
    ~Larry
    > Hi, Larry.
    layers
    can
    can
    doesn't
    us,
    if
    > explanation for it.
    > Jeff
    *Jeffrey, Dennis
    Re:
    11-10-2002 04:23 AM in reply to: *Caldwell, Larry
    Actually, you can do Insert - IGES from the pulldowns.....
    Before doing an IGESIN, you need to examine the .IGS in notepad. Look at the
    header for clues on the source of translation, and/or unit type, precision,
    etc. This can give you some insight on which option file to use in MDT. The
    option files are located in the MDT support directory....
    Dennis
    > ~Larry
    > > Hi, Larry.
    > layers
    > can
    > can
    > doesn't
    > us,
    > if
    > > explanation for it.
    > > Jeff
    Dennis Jeffrey
    CAD Associates - Fort Wayne
    Autodesk ASC
    (260-432-9695 x 221
    *Caldwell, Larry
    Re:
    11-10-2002 05:41 AM in reply to: *Caldwell, Larry
    Well, at least I can tell it was done in Rhino, what the directory it was in
    and I'd guess it was done in R5.3.
    Other than that ... looks like he went fishing for trout at the lake on the
    24th and caught 31 o'them suckers. I can also tell it was most likely done
    in Hinches instead of Hillimeters. The rest of it might as well be in
    Japanese.
    1H,,1H;,, G1
    39HD:\MyData\Temp\temp4\UV same or opp.igs, G2
    26HRhinoceros ( Apr 24 2002 ),31HTrout Lake IGES 012 Apr 24 2002, G3
    32,38,6,308,15, G4, G5
    1.0D0,1,4HINCH,1,0.01D0,13H021110.065134, G6
    0.0001D0, G7
    5.303884310917129D0,
    ~Larry
    "Dennis Jeffrey" wrote in message
    news:3DCEC03D.538961C9@cadassociates.com...
    the
    precision,
    The
    > Dennis
    of
    with
    that
    > > ~Larry
    > > > Hi, Larry.
    IGESIN.
    the
    > > layers
    I
    > > can
    Conditions -
    it
    > > can
    > > doesn't
    telling
    > > us,
    how,
    > > if
    > > > explanation for it.
    > > > Jeff
    > Dennis Jeffrey
    > Autodesk ASC
    > (260-432-9695 x 221
    *Brown, Anne
    Re:
    11-10-2002 07:09 AM in reply to: *Caldwell, Larry
    http://www.biw.com/ look under Shipbuilding. Joe's in the middle
    of a Patriot's football game so wouldn't do any more than say
    "yes dear" on ship design right now
    There is the first flat drydock launch out of the new facility
    tomorrow. Great treat for Veterans' Day to see ARLEIGH BURKE
    Class AEGIS guided missile destroyer start her life at sea.
    Anne
    Kent Keller wrote:
    (snip) It sounds to me they panels are fully formed now days
    before being welded (if I remember right....didn't read the whole
    article)
    *Maenpaa, Mike
    Re:
    11-10-2002 10:38 AM in reply to: *Caldwell, Larry
    I wish the Bears, would have concentrated as hard as he did! I can't believe
    they let the Pats have that one! :smileysad:
    Mike
    Joe's in the middle of a Patriot's football game so wouldn't do any more
    than say
    *Caldwell, Larry
    Re:
    11-10-2002 09:01 PM in reply to: *Caldwell, Larry
    For me an example of the "Surfaces U & V same or opposite" error message is
    a synch. With just the first and last profiles and the top wire the loft
    works fine. Try to make the same loft with the third profile, wire or not:
    Error. I also tried it the other way with the two profiles and two/three
    wires (other two wires made like the construction lines on the deck): same
    error. If you can say why I continually get these errors and know a way
    around it, I might actually be able to use this feature. (Emphasis on
    might.) Thanks!
    ~Larry
    > Hi, Larry.
    layers
    can
    can
    doesn't
    us,
    if
    > explanation for it.
    > Jeff
    *Howard, Jeff
    Re:
    11-11-2002 06:31 AM in reply to: *Caldwell, Larry
    Hi, Larry.
    Can only speculate that the problem is caused by the 90 deg rotation of the
    sketch plane on the nose of the shape (Sketch10). See CF for an alternate
    method. Notice also that the profiles will have to extend down into the solid
    (Sketch14). I'm assuming that all will work well then.
    Jeff
    news:EECEB9D29D1AF050D9FF6D73743FE25A@in.WebX.maYIadrTaRb...
    might.) Thanks!
    ~Larry
    *Caldwell, Larry
    Re:
    11-11-2002 07:20 AM in reply to: *Caldwell, Larry
    I'm going to try a cleaner model than that one is and see what happens using
    that technique, but did you try to shell it? I get an error that the edges
    or vertex is owned by more than two faces (i.e. part is non-manifold). Not
    sure exactly what that means though.
    ~Larry
    news:986C724CFDED3B645C99D1D4BBF5297E@in.WebX.maYIadrTaRb...
    > Hi, Larry.
    the
    alternate
    solid
    > Jeff
    is
    > might.) Thanks!
    > ~Larry
