• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    Shank Hook w/ Nose
    192 Views, 8 Replies
    01-11-2013 07:01 AM
    Happy Friday all,
    First off I'm working in Inventor Pro 2012 SP2
    I'm attempting to model a shank hook with a "nose" for a spring latch. So far I've been able to model the hook itself minus said nose by following a previous post by JDMather. Since then I've had a hard time coming up with the correct geometry for the spring latch mounting nose. I've tried a couple of methods using an extrusion for the "spine", but it doesn't play nice with the lofted face of the hook and just looks bad. Not sure if another loft is the answer or maybe something with delete face/thicken/sculpt that I"m not thinking of?
    I've attached both my .ipt & spec sheet I've been working off. Any help is appreciated.
    -Derrick
    Please use plain text.
    Distinguished Mentor
    Re: Shank Hook w/ Nose
    01-11-2013 08:02 AM in reply to: Kerdric81
    I would extrude cut the material at f3 at the 12° angle, then add back the material at g1. You'll need to adjust f3 a bit if you want it exact.
    01-11-2013 09:50 AM in reply to: rdyson
    Thanks for the response,
    I hope I understood your post correctly, so I posted my part to see if I'm on the right path. (I also found a error in sketch1 in my original .ipt) I'm still having issues adding the matterial back in. being a straight extrusion it won't follow the contour of the lofted face... If you meant for me to use a different cut extrusion profile could you clarify for me? Sorry for any confusion.
    Derrick
    *Expert Elite*
    01-11-2013 10:02 AM in reply to: Kerdric81
    Your Extrusion3 should only cut one side (half) with a 12° draft according to the drawing.  (or nto even half, but from the face of the eyelet)
    Mirror to other side or repeat for other side.
    You will need to experiment with Face Fillets.
    01-11-2013 12:58 PM in reply to: JDMather
    Ok, I believe I have the 12deg extrude cut in. Having trouble filling in the rest of the profile before mirroring though. Any suggestions?
    *Expert Elite*
    01-11-2013 01:10 PM in reply to: Kerdric81
    attach your file here.
    01-11-2013 01:19 PM in reply to: JDMather
    Bah, forgot to attach. Apologies.
    01-11-2013 02:14 PM in reply to: Kerdric81
    Don't know how exact you need it, but this might help.
    01-14-2013 07:49 AM in reply to: rdyson
    My final result, ended up using a rib instead of another extrusion but with similiar results. Doubtful my radii are all accurate but it will work for my purposes. Couldn't get a parting line face draft to work on the outer rib face for the 1:20 taper so was reduced to using 2 chamfers...Thank you rdyson & JD for your input, you guys pointed me in the right direction.
    Derrick
