• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Series 11 - Can't install Service Pack 3 or 4
    200 Views, 26 Replies
    01-23-2012 11:20 AM
    I have Inventor Series 11 with service packs 1 and 2 installed. I have been trying to install Pack 3 and I keep getting the windows installer error (see attached). I have read where redownloading the file has worked for others but it has not worked for me. I have tried downloading via both Chrome and IE. I am running XP.
    Please use plain text.
    *Expert Elite*
    blair
    Re: Series 11 - Can't install Service Pack 3 or 4
    01-23-2012 01:25 PM in reply to: gmasters
    Are you sure you have the correct version of Inventor SP?
    Inventor 11 is alot different that Inventor 2011
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    01-24-2012 04:22 AM in reply to: blair
    The box Reads Autodesk Inventor Series 11
    *Expert Elite*
    blair
    01-24-2012 08:37 AM in reply to: gmasters
    Odd, you are insting SP3 then SP4?
    Win7-64
    01-24-2012 08:49 AM in reply to: blair
    I am afraid I don't understand. The support site under Inventor Series 11 has SP3 and 4 listed. Are you suggesting it is incorrect?
    *Expert Elite*
    blair
    01-24-2012 08:55 AM in reply to: gmasters
    No, alot of people say they are on IV 11, when they mean IV 2011.
    As long as you are correct on your version, all SP's are incremental, you can't install SP2 until SP1 is installed. Double check that you do have SP2 installed before installing SP3.
    Seeams like there is something wrong with the Windows Registry, the only solution would be to un-install IV and re-install along with your SP's after.
    You should be able to export your settings.
    Just thinking, there was a DW* patch, upgrade back then and I beleive if required different Hot-Fixes.
    Win7-64
    Valued Mentor
    01-24-2012 08:58 AM in reply to: gmasters
    Are you using ADMS 2008 as well as Inventor 11? If so have you uninstalled the client upgrade as mentioned on the SP3 download page ?
    Note: If you use Autodesk Data Management Server 2008 with Autodesk Inventor 11, please note the following:
    Regards
    Martin
    PDSU 2014 RTM
    Windows 7 64bit, Office 2007 Pro
    Intel i7 980x, 24 Gb DDR3 RAM
    Geforce 580GTX Graphics (Diver 310.70)
    256GB SSD OS, 80GB SSD working folder
    Space Pilot
    01-24-2012 09:02 AM in reply to: blair
    1 and 2 installed. I installed 2 back in June.
    01-24-2012 09:12 AM in reply to: Martin_Goodland
    I am using ADMS 2011
    *Expert Elite*
    01-24-2012 09:16 AM in reply to: gmasters
    Then why are you using Inventor 11?
    I think the first thing you need to do is determine what version of Inventor you are using.
