• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    hardin
    Accepted Solution
    Self intersecting paths.... Project Geometry
    567 Views, 2 Replies
    03-07-2012 08:51 AM
    It seems when I project geometry then draw a sketch tracing over that projected geometry, I can't do anyting (offset or flange) with that sketch. It gives me the Self Intersecting paths or loops are invalid for this operation. What gives?
    How can I use those projected lines for my sketch? Things work fine in the tutorials....
    Lovin' sheet metal and skeletal design, by the way....
    Lyle
    Learn, Practice, Get Better
    http://autocad-lkh.blogspot.com
    Please use plain text.
    Distinguished Mentor
    Re: Self intersecting paths.... Project Geometry
    03-07-2012 08:54 AM in reply to: hardin
    Change projected geometry to construction if you are going to trace over it.
    John Retzlaff
    hardin
    03-07-2012 08:56 AM in reply to: john.retzlaff
    Ah... that's it. A minor thing from the tutorials I forgot.
    I also discovered I can use the projected lines as part of the sketch if I don't trace over them.
