Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Selecting Frame Generator Members In Browser vs. On Screen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I commonly need to select frame generator members to change visibility, etc. but since they are all contained in a single frame I need to do this in the browser. This can be difficult because I need to zoom in on the screen while having the section of the browser visible on screen at the same time. Is there a way that I can individually select each member in the assembly without using the browser?
Inventor 2013
Windows 7 Professional 64-bit SP1
HP EliteBook 8470w
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Memory: 16 GB
AMD FirePro M2000
3D Connexion SpacePilot
Re: Selecting Frame Generator Members In Browser vs. On Screen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Set your selection Filter to Part Priority.
Also - it looks to me like you have a lot of repeated dimensions - I prefer to use equal (=) constraints instead.
You can window or crossing window select and hit = on the keyboard.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks. When you say repeated dimensions are you referring to the top area where the grill bars are located? I use a formula here (49.438) driven dimension then reference each space divided by the number required.
How would I use the equal constraint? Highlight select and then hit = I'll try it. Thanks.
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I generally have zero dulpicated dimensions unless there is a chance that I know a couple of dimensions might need to be edited independently as the design changes.
You also have a bunch of 90° dimensions rather than Perpendicular constraints.
