• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Selecting Frame Generator Members In Browser vs. On Screen
    115 Views, 3 Replies
    11-29-2012 09:07 AM
    I commonly need to select frame generator members to change visibility, etc. but since they are all contained in a single frame I need to do this in the browser.  This can be difficult because I need to zoom in on the screen while having the section of the browser visible on screen at the same time.  Is there a way that I can individually select each member in the assembly without using the browser?
    Steve Frey
    Inventor 2013
    Windows 7 Professional 64-bit SP1
    HP EliteBook 8470w
    Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
    Memory: 16 GB
    AMD FirePro M2000
    3D Connexion SpacePilot
    Please use plain text.
    Re: Selecting Frame Generator Members In Browser vs. On Screen
    11-29-2012 09:18 AM in reply to: SteveFrey
    Set your selection Filter to Part Priority.
    Also - it looks to me like you have a lot of repeated dimensions - I prefer to use equal (=) constraints instead.
    You can window or crossing window select and hit = on the keyboard.
    11-29-2012 09:54 AM in reply to: JDMather
    Thanks.  When you say repeated dimensions are you referring to the top area where the grill bars are located?  I use a formula here (49.438) driven dimension then reference each space divided by the number required.
    How would I use the equal constraint?  Highlight select and then hit =  I'll try it.  Thanks.
    Steve Frey
    Inventor 2013
    HP EliteBook 8470w
    Memory: 16 GB
    AMD FirePro M2000
    11-29-2012 10:17 AM in reply to: SteveFrey
    I generally have zero dulpicated dimensions unless there is a chance that I know a couple of dimensions might need to be edited independently as the design changes.
    You also have a bunch of 90° dimensions rather than Perpendicular constraints.
