• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    Select profile for sweep in section view
    77 Views, 2 Replies
    05-23-2012 07:45 AM
    Hello All,
    I am trying to perform a sweep of a profile and I am unable to select the profile. I have a part with a plane through the part. I created a profile on this plane that I want to sweep along my path. However whenever I try to select the profile I am unable to, even when I sectioned the part to the created plane. What's up?
    Mon
    Please use plain text.
    Member
    Re: Select profile for sweep in section view
    05-23-2012 07:52 AM in reply to: Mech.Mon
    Hello
    I've had this before where I wanted to sweep along a profile with lots of tangency joins.  Go back and make sure all of the profile sections are properly connected to one another.  Even though the profile looks like one continuous path, it sometimes isn't (i.e. it has gaps).  Try deleting half of the profile at a time and re-try the sweep to try and narrow down which bit of the profile that isn't happy, you can then home in on that section to see if something needs constraining.
    Hope that helps.
    Dave
    05-23-2012 08:06 AM in reply to: Mech.Mon
    Thanks Dave, but my problem was a projected loop in the profile. All fixed.
    Mon
