• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Select origin?
    226 Views, 6 Replies
    10-04-2012 05:47 AM
    I cannot select origin to constrain sketch with dimension to origin?
    I selected Sketch,
    expanded origin,
    selected mywork plan (xy)
    drew rectangle,
    input dims,
    right click for marking menu,
    selected dimensions,
    Origin is yellow,
    cannot select it and then edge of rect to set dim that will center sketch on origin?
    Just like the videos show, but cannot select origin>
    Please advise?
    spacebeagle
    Please use plain text.
    Re: Select origin?
    10-04-2012 05:55 AM in reply to: asbuiltjmh1
    Project Geometry
    What version of Inventor are you using?  This should be automatic.
    http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
    Distinguished Contributor
    Re: Select origin?
    10-04-2012 09:21 AM in reply to: asbuiltjmh1
    You should be able to. Can you post the file with the offending sketch?
    Re: Select origin?
    10-04-2012 03:08 PM in reply to: JDMather
    Ver. 2013
    Thanks for the input.
    I went through the 60 tips.
    I appreciate your response and the links to resources!
    Jim
    Re: Select origin?
    10-04-2012 03:11 PM in reply to: asbuiltjmh1
    Ver. 2013 Inventor Lt Suite to be perfectly accurate.
    Thanks.
    P.S. Any other thoughts or suggestions will be immensely appreciated.
    Jim
    mrattray
    Re: Select origin?
    10-05-2012 04:33 AM in reply to: asbuiltjmh1
    This is for a full version of Inventor 2013, but I imagine LT has a similar option somewhere.
    Mike (not Matt) Rattray
    Re: Select origin?
    10-05-2012 09:51 AM in reply to: asbuiltjmh1
    Yes, mrattray, that in fact was the step I missed.
    Thanks again for everyone's input.
    spacebeagle
