Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Select origin?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I cannot select origin to constrain sketch with dimension to origin?
I selected Sketch,
expanded origin,
selected mywork plan (xy)
drew rectangle,
input dims,
right click for marking menu,
selected dimensions,
Origin is yellow,
cannot select it and then edge of rect to set dim that will center sketch on origin?
Just like the videos show, but cannot select origin>
Please advise?
spacebeagle
Re: Select origin?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Project Geometry
What version of Inventor are you using? This should be automatic.
http://home.pct.edu/~jmather/SkillsUSA%20Universit
Re: Select origin?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should be able to. Can you post the file with the offending sketch?
Re: Select origin?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ver. 2013
Thanks for the input.
I went through the 60 tips.
I appreciate your response and the links to resources!
Jim
Re: Select origin?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ver. 2013 Inventor Lt Suite to be perfectly accurate.
Thanks.
P.S. Any other thoughts or suggestions will be immensely appreciated.
Jim
Re: Select origin?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is for a full version of Inventor 2013, but I imagine LT has a similar option somewhere.
Re: Select origin?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks again for everyone's input.
spacebeagle
