Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Select Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I work with inv 2012 and zoom with the Space Pilot of 3d Connexion.
If I zoom in or out and I come with my cursor over an object the view of Select Other comes out and I keep hanging in the zoom and I can not use more zoom in or out.
I have tried to deselect Select Other but I can not unless I uncheck the wrong button.
Do this under Application Options - General-Selection.
I wonder if this is the Space Pilot or Inventor.
Have the latest drivers installed.
Has anyone experience with this?.
Your drawings are only as good as the symbols that complete them...
Re: Select Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for reporting this.
I’m tried times as you said, but I failed to reproduced it. Would you please give more information, such as snapshot or video, so that I can continue to investigate more on this problem?
Thanks!
Re: Select Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I try to make a movie, i'll be back![]()
Re: Select Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Maybe you need SP1 - issues addressed in Select Other tool
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Application Enginner
Cadtech.Asidek | Autodesk Gold Partner
http://cadtech-asidek.blogspot.com/
www.cadtech.pt | www.cadtech.es | www.asidek.es
Autodesk Inventor Professional 2013
Windows 7 Professional 64-bit
Re: Select Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Also click Calibrate on your 3DConnexion Control Panel.
I recommend you calibrate at the beginning of each day or when any problem with user interface occurs.
(particularly if you try to resize the browser and it responds very slowly)
Inventor Professional 2014 Edu 64-bit
Re: Select Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have already installed SP1 and i did calibrate but that makes no difference.
I made a small movie and made a print screen.
Every time i go over an object white my cursor the zoom action white my space pilot stops.
Here is the link where you can down load the file Zoom where the movie and print screen is in.
http://www.4shared.com/folder/5sB3nZBY/_online.htm
Re: Select Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I was wondering if I can expect a solution very soon.![]()
Re: Select Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try updating your mouse drivers.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 320.18
SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
Re: Select Other
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
After i instaled inv 2012 i instaled also a new mouse driver, this was an beta driver:http://www.3dconnexion.com/supported-software/3dxl
Now i instaled a new driver the problem is over.
This is a bug for 3d Connexion.
