• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Spinner99
    Segment Point Dimension constraint?
    98 Views, 2 Replies
    03-30-2011 04:44 AM
    In laying down a segment you can specify the height above the surface. If you want to move the point around, you can use the 3D move command.
    Is it possible to constrain this point by dimesioning to other geometry?
    Please use plain text.
    **Master
    Re: Segment Point Dimension constraint?
    03-30-2011 11:16 PM in reply to: Spinner99
    Are you talking about Routed Systems?
    I think you need to provide more details in order to get a better response, your question is not clear.
    Spinner99
    03-31-2011 06:38 AM in reply to: BMiller63
    Yes I am talking about Routed Systems. Once again, I found the answer by trial and error.I was waiting for the projected line from the pointer to snap to the work point, instead of selecting it directly with the pointer.So the answer to my question is: Yes it can.
