Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Section view in I6 sp1
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
34 Views, 2 Replies
11-25-2002 10:44 PM
I'm having problems with sectioning an assembly in Inventor version 6 sp1, which I believe worked correctly in version 5.3. I have a simple round part with twelve evenly spaced tapped holes (in a polar pattern) and twelve bolts. I define the section cut to start horizontally thru the bolt at 3 o'clock, to the center of the part, then at an angle that passes thru the bolt at 10 o'clock. At this point, every looks great. I then "show contents" in the base view, select all the bolts, and turn off "section" for these parts. The bolts at the 10 o'clock position and 11 o'clock position no longer appear in the section view! I expected the bolts to appear in the section view, just not sectioned. Can anyone else produce the same results? Am I doing something wrong? Any help would be greatly appreciated. Thanks
*KJohnson
Re: Section view in I6 sp1
Options
- Highlight
- Email to a Friend
11-25-2002 11:00 PM in reply to:
dhoerig
I had the same problem and was told that 5.3
did sectioning wrong. 6 is how it should be. I don't know a work around
though. Sorry
though. Sorry
Kathy Johnson
"dhoerig" <I'm
href="mailto:dhoerig@shafervalve.com">dhoerig@shafervalve.com> wrote in
message
href="news:f127718.-1@WebX.maYIadrTaRb">news:f127718.-1@WebX.maYIadrTaRb...
*Jayabal, Sanjay
Options
- Highlight
- Email to a Friend
11-26-2002 05:25 AM in reply to:
dhoerig
What you are seeing is not the correct or expected
behavior. I have the issue logged internally. This happens only
on aligned section views. Thank you!
-Sanjay Jayabal
Autodesk, Inc.
"dhoerig" <I'm
message
