• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Mentor
    Accepted Solution
    Section View Properties in iam
    174 Views, 7 Replies
    12-10-2012 12:57 PM
    Using half / quarter section view, I know how to section CC parts.
    How do I NOT section custom parts?
    There has to be setting somewhere. Anyone know?
    Please use plain text.
    *Expert Elite*
    Cadmanto
    Re: Section View Properties in iam
    12-10-2012 01:32 PM in reply to: rdyson
    You are talking about something similar to the Display Options under "Section Standard Parts" where you can select which groups you want sectioned except this in assembly mode I am assuming.
    Or are you looking for something where you can randomly select individual parts that you don't want sectioned in the assembly model.
    Either way I am not seeing anything that does this in the model.  If there is I would like to know myself as well.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    New Member
    12-10-2012 11:59 PM in reply to: rdyson
    I guess you are looking for 'participate in assembly and drawing sections' you find this checkbox in the part environment
    tools --> document settings --> modeling tab
    i hope this helps!
    12-11-2012 06:44 AM in reply to: Cadmanto
    Curtis,
    There is obviously some setting that allows / causes CC parts to not participate in sectioning in the assembly environment. (see below)
    I was looking for a way to make one of my parts behave the same.
    12-11-2012 06:59 AM in reply to: rdyson
    Edit the part you don't want sectioned and uncheck this box in document settings.12-11-2012 8-58-00 AM.png
    John Retzlaff
    12-11-2012 09:21 AM in reply to: john.retzlaff
    Thanks you! Knew it had to be somewhere.
    *Expert Elite*
    Cadmanto
    12-11-2012 10:34 AM in reply to: john.retzlaff
    John,
    Thanks for the tip.
    It is a shame that this is not built into the actual section command itself, like I have experienced in other softwares.
    Where you can select components not to be affected while in the command.
    Best Regards,
    Scott McFadden
    12-11-2012 10:35 AM in reply to: Cadmanto
    Yes, sure would be nice if you could change this at the assembly level.
    John Retzlaff
