Autodesk Inventor
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Caldwell, Larry
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-17-2002 01:47 AM in reply to:
*Caldwell, Larry
Every time I save it it insist on resaving
it. That must be it; maybe the reason Jeff didn't see it, might have been
because the iPart wasn't in the Library search path. Have you tried to use the
same iPart with it in some other directory than the Library path maybe, to see
if there could be some problem with the read-only deal?
~Larry
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Sean Dotson" <sean at sdotson dot com> wrote in message
href="news:649BB9A3F0EF187C0705DC6B7DCC0C44@in.WebX.maYIadrTaRb">news:649BB9A3F0EF187C0705DC6B7DC......
I get it with my ipart save bug all of the
time. It seems like it's still trying to save the ipart children (and
factory <grrr>) when the second save is issued.
You have iparts in this assy right? You
aren't seeing the ask to save the factory error are you?
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
"Larry Caldwell" <
href="mailto:lc@houston.rr.com">lc@houston.rr.com> wrote in message
href="news:46F9D2C15C9127BA08C5687CA1CCCDB9@in.WebX.maYIadrTaRb">news:46F9D2C15C9127BA08C5687CA......
That's the error okay. You know what it might
be?
~Larry
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F09C83B5......
Is the error like the one I posted in
CF?
Sean Dotson, PE
Check the
Inventor FAQ for most common questions
"Larry Caldwell" <
message
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC3A9298......
Put a file in CF; kind of big (3 MB), but
probably faster than having to roll-down the EOP in all the ipt files if
anyone wants to have a look.
This is an assembly that works okay but
if I save it after it's already been saved (...did I save this yet?)
it returns a file save error. Okay that out, pick close, the save
dialog comes up again and it saves okay then. ... Huh? ... The
individual subs didn't do that, only when I get the complete assembly
together does it start. The reason I know is because I rebuilt the
assembly to see if a new one would do it as well; yep it does. Are my
skates on backwards or something? Wonder if the same thing would happen
to someone else if anyone wants to give it a shot.
~Larry
*Howard, Jeff
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-17-2002 01:52 AM in reply to:
*Caldwell, Larry
I did set it up in a library path, but before opening the assembly I dropped
instances of each spring into a dummy assembly to create the children, so that
might have been a factor. If you kill your library paths and re-path to them
as locals does it still complain?
"Larry Caldwell" wrote in message
news:B65E0A7FBD1A6FF6774D2A1577F63CC8@in.WebX.maYI adrTaRb...
Every time I save it it insist on resaving it. That must be it; maybe the
reason Jeff didn't see it, might have been because the iPart wasn't in the
Library search path. Have you tried to use the same iPart with it in some
other directory than the Library path maybe, to see if there could be some
~Larry
"Larry Caldwell"
~Larry
*Caldwell, Larry
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-17-2002 02:04 AM in reply to:
*Caldwell, Larry
If delete the springs or place them from an off-library path, the problem
goes away; can't
make it produce the save error or bring up the repetitive save dialog.
Something must be up with that read-only directory thingy.
~Larry
"Jeff Howard" wrote in message
news:EE17A4EF85EE9C6BD3EE968B139ECA25@in.WebX.maYI adrTaRb...
dropped
that
them
> ~Larry
goes away; can't
~Larry
"Jeff Howard"
dropped
that
them
> "Larry Caldwell"
> ~Larry
*Dotson, Sean
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-17-2002 02:17 AM in reply to:
*Caldwell, Larry
Check CF again. Ever see this
dialogue?
dialogue?
I think there is a problem with the read-only
nature of libraries. This is part of the ipart save bug that I've been
griping about for some time. Strange things is if I change Library to YES
it will actually save the factory (a library pathed part)
BTW if I change it to a non-library path it still
asks me to save the factory....
go figure....
Sean Dotson, PE
Check the Inventor
"Larry Caldwell" <
href="news:B65E0A7FBD1A6FF6774D2A1577F63CC8@in.WebX.maYIadrTaRb">news:B65E0A7FBD1A6FF6774D2A1577F......
~Larry
href="news:649BB9A3F0EF187C0705DC6B7DCC0C44@in.WebX.maYIadrTaRb">news:649BB9A3F0EF187C0705DC6B7......
Sean Dotson, PE
Check the
"Larry Caldwell" <
href="news:46F9D2C15C9127BA08C5687CA1CCCDB9@in.WebX.maYIadrTaRb">news:46F9D2C15C9127BA08C5687......
might be?
~Larry
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F09C83......
CF?
Sean Dotson, PE
Check the
"Larry Caldwell" <
message
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC3A92......
but probably faster than having to roll-down the EOP in all the ipt
files if anyone wants to have a look.
happen to someone else if anyone wants to give it a shot.
~Larry
*Caldwell, Larry
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-17-2002 02:38 AM in reply to:
*Caldwell, Larry
Yeah ... I've seen it ... I remembered that you
have been mentioning it so I figured they were on it! <G>
~Larry
href="news:8C6EF91BFE05C8F9C416207F860E2D52@in.WebX.maYIadrTaRb">news:8C6EF91BFE05C8F9C416207F860......
dialogue?
YES it will actually save the factory (a library pathed part)
go figure....
Sean Dotson, PE
Check the Inventor
"Larry Caldwell" <
href="news:B65E0A7FBD1A6FF6774D2A1577F63CC8@in.WebX.maYIadrTaRb">news:B65E0A7FBD1A6FF6774D2A157......
been because the iPart wasn't in the Library search path. Have you tried to
use the same iPart with it in some other directory than the Library path
maybe, to see if there could be some problem with the read-only
deal?
~Larry
href="news:649BB9A3F0EF187C0705DC6B7DCC0C44@in.WebX.maYIadrTaRb">news:649BB9A3F0EF187C0705DC6......
(and factory <grrr>) when the second save is issued.
Sean Dotson, PE
Check the
"Larry Caldwell" <
message
href="news:46F9D2C15C9127BA08C5687CA1CCCDB9@in.WebX.maYIadrTaRb">news:46F9D2C15C9127BA08C56......
might be?
~Larry
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F09C......
CF?
Sean Dotson, PE
Check the
"Larry Caldwell" <
message
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC3A......
but if I save it after it's already been saved (...did I save this
yet?) it returns a file save error. Okay that out, pick close,
the save dialog comes up again and it saves okay then. ... Huh? ...
The individual subs didn't do that, only when I get the complete
assembly together does it start. The reason I know is because I
rebuilt the assembly to see if a new one would do it as well; yep it
does. Are my skates on backwards or something? Wonder if the same
thing would happen to someone else if anyone wants to give it a
shot.
~Larry
*Caldwell, Larry
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-17-2002 02:43 AM in reply to:
*Caldwell, Larry
BTW, I pulled the iPart spring from my off-path
iPart Modification directory, so it was the same iPart but it had never been in
the read-only library path since it was modified. The copy I saved to the
library path is the one that gives the problem.
~Larry
"Larry Caldwell" <
href="news:6AA47A53CC4FE9639C0EFA7D90A1D69C@in.WebX.maYIadrTaRb">news:6AA47A53CC4FE9639C0EFA7D90A......
~Larry
href="news:8C6EF91BFE05C8F9C416207F860E2D52@in.WebX.maYIadrTaRb">news:8C6EF91BFE05C8F9C416207F8......
dialogue?
still asks me to save the factory....
go figure....
Sean Dotson, PE
Check the
"Larry Caldwell" <
href="news:B65E0A7FBD1A6FF6774D2A1577F63CC8@in.WebX.maYIadrTaRb">news:B65E0A7FBD1A6FF6774D2A1......
to use the same iPart with it in some other directory than the Library
path maybe, to see if there could be some problem with the
read-only deal?
~Larry
href="news:649BB9A3F0EF187C0705DC6B7DCC0C44@in.WebX.maYIadrTaRb">news:649BB9A3F0EF187C0705D......
You aren't seeing the ask to save the factory error are
you?
Sean Dotson, PE
Check the
"Larry Caldwell" <
message
href="news:46F9D2C15C9127BA08C5687CA1CCCDB9@in.WebX.maYIadrTaRb">news:46F9D2C15C9127BA08C......
might be?
~Larry
href="news:C88FB55E0E51C19F09C83B5F13CC1919@in.WebX.maYIadrTaRb">news:C88FB55E0E51C19F0......
CF?
Sean Dotson, PE
Check
the Inventor FAQ for most common questions
"Larry Caldwell" <
message
href="news:1C7CBABAAE881EC3A9298BE94C4AACA7@in.WebX.maYIadrTaRb">news:1C7CBABAAE881EC......
MB), but probably faster than having to roll-down the EOP in all
the ipt files if anyone wants to have a look.
close, the save dialog comes up again and it saves okay then. ...
Huh? ... The individual subs didn't do that, only when I get the
complete assembly together does it start. The reason I know is
because I rebuilt the assembly to see if a new one would do it as
well; yep it does. Are my skates on backwards or something? Wonder
if the same thing would happen to someone else if anyone wants to
give it a shot.
~Larry
