Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Search Dimension
- Highlight
- Email to a Friend
- Report Inappropriate Content
I have a long model tree. In the Fx (Parameter dialog) I can see tons of d## numbers. I see one of it as d136. I want to know where in the model its used.
Possible?
Inventor Professional 2013
Vault Collaboration 2013
Re: Search Dimension
- Highlight
- Email to a Friend
There should be a way !!
Come-on, Autodesk ?
- Highlight
- Email to a Friend
Hi CAD-One,
I have a rough iLogic rule to do this, but it's a bit buggy. If I have time to clean it up, would iLogic work for you?
I hope this helps.
Curtis
- Highlight
- Email to a Friend
I tried this quickly, and it seemed to point me to the sketch I needed anyway. Go to the "find" button. Under property select "sketch parameter name", and for the condition, select "contains". Type the search parameter (d136) and Add to the search list, and hit "find now". The sketch containing the dimension should highlight. From here, edit the sketch to show dims, which you can do by changing the dimension display to name instead of value.
Hope that helps. Not as quick and slick as maybe right clicking on the value in the parameter list, and zeroing in on it from there.
- Highlight
- Email to a Friend
Hi CAD-One,
Here's an ilogic rule to search for parameters. It's not promised to be perfect, but it seems to be working fairly smoothly now. Attached is an example file also.
I hope this helps.
Curtis
Dim oDoc As Inventor.PartDocument
Dim TargetName As String
Dim oCompDef As Inventor.PartComponentDefinition
Dim oSketch As PlanarSketch
Dim oFeature As PartFeature
Dim oConstr As DimensionConstraint
Dim oParams As Parameters
Dim oModelParam As ModelParameter
Dim oParam As Parameter
Dim oCmdMgr As CommandManager
Dim oSet1 As Inventor.HighLightSet
Dim oFound As Boolean
‘get the Inventor user name from the Inventor Options
myName= ThisApplication.GeneralOptions.UserName
oDoc = ThisApplication.ActiveDocument
oCompDef = oDoc.ComponentDefinition
oParams = oCompDef.Parameters
oSet1 = oDoc.CreateHighlightSet
TargetName = InputBox("Enter the name of the paramter you wish to find.", "iLogic", "")
For Each oSketch In oCompDef.Sketches
For Each oConstr In oSketch.DimensionConstraints
If oConstr.Parameter.Name = TargetName Then
oSketch.Edit
oDoc.SelectSet.Select(oSketch)
ThisApplication.CommandManager.ControlDefinitions. Item("AppZoomSelectCmd").Execute
ThisApplication.CommandManager.ControlDefinitions. Item("AppLookAtCmd").Execute
ThisApplication.ActiveView.Update()
oSet1.AddItem(oConstr)
oSet1.SetColor(255,0,0)
MessageBox.Show("Hi " & myName & ", " & vblf & _
TargetName & vblf & "is highlighted.", "iLogic")
oFound = True
Next
Next
If oFound = True then
Return
Else
For Each oFeature In oCompDef.Features
For Each oParam in oFeature.Parameters
If oParam.Name = TargetName Then
oDoc.SelectSet.Select(oFeature)
oSet1.AddItem(oFeature)
TargetName & vblf & "is located in: " & vblf & oFeature.Name, "iLogic")
oFound = True
Next
Next
End if
If oFound <> True then
MessageBox.Show("A model parameter named: " _
& vblf & TargetName & vblf & "was NOT found.", "iLogic")
End if
- Highlight
- Email to a Friend
You are amazing. Thanks for the help. I will try them soon.
Thx
- Highlight
- Email to a Friend
In the paramaters dialog box, hover your cursor over the parameter name (d136 in your example). Do you get a tooltip with info about where the parameter is used?
- Highlight
- Email to a Friend
That makes it easier.
