• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    CAD-One
    Search Dimension
    206 Views, 7 Replies
    06-21-2012 06:08 AM
    I have a long model tree. In the Fx (Parameter dialog) I can see tons of d## numbers. I see one of it as d136. I want to know where in the model its used.
    Possible?
    C1
    Inventor Professional 2013
    Vault Collaboration 2013
    Please use plain text.
    CAD-One
    Re: Search Dimension
    06-21-2012 12:37 PM in reply to: CAD-One
    There should be a way !!
    Come-on, Autodesk ?
    C1
    Curtis_Waguespack
    06-21-2012 12:46 PM in reply to: CAD-One
    Hi CAD-One,
    I have a rough iLogic rule to do this, but it's a bit buggy. If I have time to clean it up, would iLogic work for you?
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    06-21-2012 01:04 PM in reply to: CAD-One
    I tried this quickly, and it seemed to point me to the sketch I needed anyway.  Go to the "find" button.  Under property select "sketch parameter name", and for the condition, select "contains".  Type the search parameter (d136) and  Add to the search list, and hit "find now".  The sketch containing the dimension should highlight.  From here, edit the sketch to show dims, which you can do by changing the dimension display to name instead of value.
    Hope that helps.  Not as quick and slick as maybe right clicking on the value in the parameter list, and zeroing in on it from there.
    Curtis_Waguespack
    06-21-2012 01:52 PM in reply to: Curtis_Waguespack
    Hi CAD-One,
    Here's an ilogic rule to search for parameters. It's not promised to be perfect, but it seems to be working fairly smoothly now. Attached is an example file also.
    I hope this helps.
    Curtis
    Dim oDoc As Inventor.PartDocument
    Dim TargetName As String
    Dim oCompDef As Inventor.PartComponentDefinition
    Dim oSketch As PlanarSketch
    Dim oFeature As PartFeature
    Dim oConstr As DimensionConstraint
    Dim oParams As Parameters
    Dim oModelParam As ModelParameter
    Dim oParam As Parameter
    Dim oCmdMgr As CommandManager
    Dim oSet1 As Inventor.HighLightSet
    Dim oFound As Boolean
    ‘get the Inventor user name from the Inventor Options
    myName= ThisApplication.GeneralOptions.UserName
    oDoc = ThisApplication.ActiveDocument
    oCompDef = oDoc.ComponentDefinition
    oParams = oCompDef.Parameters
    oSet1 = oDoc.CreateHighlightSet
    TargetName = InputBox("Enter the name of the paramter you wish to find.", "iLogic", "")
    For Each oSketch In oCompDef.Sketches
        For Each oConstr In oSketch.DimensionConstraints
        	If oConstr.Parameter.Name = TargetName Then
    	oSketch.Edit
    	oDoc.SelectSet.Select(oSketch)
    	ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomSelectCmd").Execute
    	ThisApplication.CommandManager.ControlDefinitions.Item("AppLookAtCmd").Execute
    	ThisApplication.ActiveView.Update()
    	oSet1.AddItem(oConstr)
    	oSet1.SetColor(255,0,0)
    	MessageBox.Show("Hi " & myName & ",  " & vblf & _
    	TargetName & vblf & "is highlighted.", "iLogic")
    	oFound = True
        	End If
        Next
    Next
    If oFound = True then
    Return
    Else
    For Each oFeature In oCompDef.Features
    	For Each oParam in oFeature.Parameters
    	            If oParam.Name = TargetName Then
    		oDoc.SelectSet.Select(oFeature)
    		oSet1.AddItem(oFeature)
    		TargetName & vblf & "is located in: " & vblf & oFeature.Name, "iLogic")
    		oFound = True
    		End If
    	Next
    Next
    End if
    If oFound <> True then
    MessageBox.Show("A model parameter named:  " _
    & vblf & TargetName & vblf & "was NOT found.", "iLogic")
    End if
    CAD-One
    06-21-2012 03:25 PM in reply to: CAD-One
    Guys,
    You are amazing. Thanks for the help. I will try them soon.
    Thx
    C1
    *Pro
    06-22-2012 04:01 AM in reply to: CAD-One
    In the paramaters dialog box, hover your cursor over the parameter name (d136 in your example).  Do you get a tooltip with info about where the parameter is used?
    CAD-One
    06-22-2012 04:49 AM in reply to: CAD-One
    Awesome tip dude ! Never noticed it.
    That makes it easier.
    C1
