• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Seam in a cylinder
    278 Views, 2 Replies
    04-28-2012 09:50 PM
    I have made a sheet metal cylinder with a rip. I am trying to create a seam on this rip as is done in http://www.youtube.com/watch?v=gazPCkD8jrQ about half way through.
    I have tried to go through the same steps, but I can not select the inside of the rip to built hems and flanges on.  I also tried to make the cylinder by sketching 350 degrees of the cylinder instead of creating a rip, This had the same problem.
    Does anybody know why I can't select these edges or how I can work around it?
    Please use plain text.
    Re: Seam in a cylinder
    04-30-2012 04:32 AM in reply to: kortekaasmark
    Maybe something like this is what you are after.
    New Member
    04-30-2012 04:48 PM in reply to: JDMather
    It's not exactly what I was looking for but i can definately work with that.
    Thank you!
