• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Scale dimensions in IDW drawing
    146 Views, 1 Replies
    01-11-2013 10:12 AM
    Simply put I'd like to take a set of ordinate dimensions and multiply all the values by 10. Is this possible, without overriding the values and making them static?
    The reason I'm asking is because I'm making a flat layout sketch for pockets around a drum. So imagine taking a drum and rolling it out flat. In the direction along the drum I drew it as 1" = 1" and for the circumfrence direction I did 1" = 10° so I don't have sketch that is 13" x 360". So I need to scale the dimensions in 1 direction up by 10.
    Please use plain text.
    *Pro
    sbixler
    Re: Scale dimensions in IDW drawing
    01-11-2013 05:43 PM in reply to: pball
    Quick answer is 'no'.  That said, I'm sure that a macro or iLogic rule could be written to make this happen for you.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
