• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    New Member
    Scale a part
    106 Views, 1 Replies
    01-06-2013 02:36 AM
    Hello, I am a new inventor user. I made several parts but I made their dimensions wrong. For example instead of 62mm I made 6,2 mm. I want to scale them but after scaling I want to use them like an original part. I want to change the dimensions when needed. Is it possible? In the forum I read that deriving a part is solution but hot it works? I didn't understand exactly. Thank You
    Please use plain text.
    *Expert Elite*
    Re: Scale a part
    01-06-2013 07:06 AM in reply to: guneskupelioglu
    I recommend that you simply do the parts over from scratch (and correctly this time).
    Almost every part I have ever made - I did at least two attempts and often many many more than two.
    The experience will be good and it won't be nearly as much work as you might think.
