• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    KingDraw
    Saving files as dwg
    128 Views, 3 Replies
    02-16-2013 11:22 PM
    Hi All,
    I have asked this question before on several forums without any resolution.  I have just purchased a new computer running Windows 7.  My Inventor is 2011 Professional - Student.  Now without anything else installed I installed my Inventor program, so everthing is clean and Inventor cannot be interferred with by anything else.
    Yet I still cannot save/export a drawing to Autocad dwg of dxf.  Why!!  Both programs are from the same stable - Autodesk.  Catia is there along with Parasolid, Pro/Engineer etc.  Surely there is something that either I'm not doing right or the program is faulty.
    WHAT PRAY IS THE ANSWER!!
    Dave R
    Please use plain text.
    Member
    Re: Saving files as dwg
    02-17-2013 07:37 AM in reply to: KingDraw
    i do not believe the student version will allow you to do this. if it were to allow you, then you could remove the plot stamp about educational version blah blah... sorry:smileysad:
    02-17-2013 09:16 AM in reply to: rbarnhill8138
    rbarnhill8138 wrote:
    i do not believe the student version will allow you to do this....
    There is no difference in functionality between the commercial license and the student license.
    I have run student license (as an instructor) for years and can save as dwg  or dxf just fine.
    Was Inventor installed with UAC and anti-virus off?
    Have you installed all Service Packs?
    Where is your instructor, it would be far easier to diagnose this problem sitting at the keyboard.
    Active Member
    KingDraw
    02-18-2013 01:34 AM in reply to: KingDraw
    Hi There,
    YES, I made doublely sure that UAC was turned off and being a new computer I have not put any Anti-Virus programs on yet.  One thing I did notice when installing Inventor was a tick box that basically sain to install Inventor in default mode of with Autocad settings, or some such wording.  I opted for default mode thinking that this is only for the menu bars - Right or Wrong?
    Best Rgds,
    Dave R
