• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Bedford, Chris
    Saving IDW as DWG file
    35 Views, 5 Replies
    11-19-2002 09:54 AM
    Is there a comprehensive tutorial anywhere that covers the process of saving
    IDW's as DWG files?
    I am looking for information on controlling layers, groups, model/paper
    space etc.
    This seems to be an process that is still a bit dodgy. I was hoping IV6
    would make things a bit clearer on how to control the process better.
    Chris B
    Please use plain text.
    *Germer, Ole
    Re: Saving IDW as DWG file
    11-19-2002 10:03 AM in reply to: *Bedford, Chris
    It is still so. It is getting better but not there yet.
    Ole Germer
    Helping create better involute profiles for gears
    http://www.geocities.com/olegermer/index.html
    "Chris Bedford" wrote in message
    news:62F619106F4D29568F14E39C4D638724@in.WebX.maYIadrTaRb...
    saving
    > IDW's as DWG files?
    > space etc.
    > Thanks
    > Chris B
    Active Contributor
    11-19-2002 01:25 PM in reply to: *Bedford, Chris
    I have found that the whole process is far superior. what I do is create all of the idws complete with sections and details and demensions. Normaly this is done using several sheets. After I have everything that I want using the company title block and border to look just how I want AutoCad to plot I Saves as a DWG. In that dialog box make sure to SAVE IN Model and Paper Space. there is is a option to change the layer to mechanical naming. Hit the save button to save in the directory you want it and presto.
    Open the DWG and on layout space wil be all the text and dimensions and ready for plotting (paper space). the model space will be the dwg at full scale as normal. My dwgs are uselly 3-8 sheets. I just wish that I could figure out how to xref them to inventor so when I update they would also.
    I will save that for an other time.
    *Germer, Ole
    Re:
    11-19-2002 09:32 PM in reply to: *Bedford, Chris
    Wonderful Mr.Clark.
        I do drawings for customers who
    want autocad drawings as the final product.  They get it even if the model
    is Inventors.
        The problem with exported to dwg
    is that the format that inventor creates is not the convention that people are
    use to seeing in autocad drawings.
        1.  Most autocad drawings
    are still done in color and not black and white.
        2.  Most autocad drawings
    plot using color as a lineweight.
        3. Most autocad drawings do not
    do centerlines as blocks.  They are usually done on separate
    layers.
        4.  Customers do want to
    change the drawings that you do.  Change a few things, like add some more
    information,  Material spec or method of fabrication or move a
    view and cannot understand what you screw up.  They want autocad
    drawings and not inventors.
        I know that to fully get the
    benefits of Inventor, the final product or manufacturing drawings should be
    inventors.  Autodesk spent many years trying to teach the uninformed how to
    do drawings -- Autocad drawings.  They set the standards for much of the
    cad world.  To succeed in bringing that same slice of the cad world into 3d
    you need those user friendly tools.
        WHAT IS
    NEEDED.
        1. Do away with the block that
    generated by Inventor for centerlines and all the small stuff.
        2. Give us direct translation to
    colors and not lineweight and linetype to autocad linetype.
        What is needed for
    Autocad.
        1.  Please write a routine
    for the "Cad Standard" so it can handle Inventors convention.  Could be an
    add-on to Autodesk's Cad Standard or just part of the
    program.
    My 5 cents worth.
    face=Arial size=2>
    I
    Open the DWG and on
    time.
    Active Contributor
    Re:
    11-20-2002 05:03 AM in reply to: *Bedford, Chris
    Ole
    That is a very good point. I haven't looked at it that way
    Of course I am still using a pen plotter also. Your comment is well worth taking.
    Valued Contributor
    Re:
    11-20-2002 05:13 AM in reply to: *Bedford, Chris
    I know its another step, but until ADesk or someone creates a flawless and 1-step process for translating, I have found it quite easy to use AutoCAD's layer translator. If your convention is as ours is, (each linetype is a different layer/color) then this is a snap. If you have your layers set to different part of the machine/assembly, this won't work.
