• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Sanders, Randy
    Saveas changing both files
    26 Views, 4 Replies
    12-02-2002 01:33 AM
    I have found that when I do a save as to a different name in a different
    directory, it changes the part number, in the iProperties, for the current
    part to the name I saved it to. Do anyone else experience this? Why would
    they change the current part, if they are not going to change it to the save
    as part like every other product does
    Please use plain text.
    *Dotson, Sean
    Re: Saveas changing both files
    12-02-2002 04:33 AM in reply to: *Sanders, Randy
    I am not seeing this. Are you running SP1? Perhaps it was a bug that was
    fixed by SP1...
    Sean Dotson, PE
    http://www.sdotson.com
    Check the Inventor FAQ for most common questions
    "Randy Sanders" <7randys7@7striker7-7systems7.com> wrote in message
    news:79703BCC341D3EAF763094A55D277B81@in.WebX.maYIadrTaRb...
    save
    *Sanders, Randy
    Re:
    12-02-2002 07:06 AM in reply to: *Sanders, Randy
    Yes I am. I originally posted this in the customization group because I am
    doing the save as through my program. I will check it tomorrow and see if it
    is only when my program does the saveas.
    "Sean Dotson" wrote in message
    news:AB80FF2F70D568EAB4DE1071601598C5@in.WebX.maYIadrTaRb...
    > fixed by SP1...
    > Sean Dotson, PE
    current
    would
    > save
    *Dotson, Sean
    Re:
    12-02-2002 08:22 AM in reply to: *Sanders, Randy
    Ah..you have a VBA script. That changes things...
    Sean Dotson, PE
    news:BBF6687D6AE208E989250AF2647CEDA6@in.WebX.maYIadrTaRb...
    it
    was
    > > fixed by SP1...
    > > Sean Dotson, PE
    different
    > current
    > would
    the
    > > save
    *Sanders, Randy
    Re:
    12-03-2002 12:26 AM in reply to: *Sanders, Randy
    After further testing, I found that it only happens when my program does the
    save as. I will have to report it to Autodesk and see what they say about
    it.
    news:0D889F59ADB0040CBDC7BB50A57762A4@in.WebX.maYIadrTaRb...
    > Sean Dotson, PE
    am
    if
    > it
    > was
    > > > fixed by SP1...
    > > > Sean Dotson, PE
    > different
    > > current
    > > would
    > the
    > > > save
